Triumph Sports Cars
oldguy
Guy Cosmo
(7 posts)
06/19/2019 09:57PM
TR6 electric steer - EPS
Posted by: oldguy
Date: August 31, 2019 02:23AM
My version of electric steering. not as polished as some of the others, but very easily accomplished.
Edited 3 time(s). Last edit at 09/11/2019 10:04AM by MGBV8.
(4512 posts)
Re: tr6 electric steer
Date: August 31, 2019 09:19AM
Probably because they are too large. There are a number of free online sites to bring them down to a manageable size. Drop the width to 600 pixels.
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
1974 TR6 Ford 5.0 HO
Posted by: dwtr6v8
Date: September 01, 2019 08:10PM
Do post details, I'm still playing with my conversion.
oldguy
Guy Cosmo
(7 posts)
06/19/2019 09:57PM
Posted by: oldguy
Date: September 09, 2019 11:16AM
Carl was going to reconfigure the photos so they could be up loaded.
I mounted the the unit in the engine compartment. I used a 1/2 drive universal joint to couple the the unit to the steering column. I shaped the male end of the universal to fit into the column and used the original clamp to secure the joint. I shortened the input shaft of the unit and machined it square to fit into the female end of the universal joint. A standard universal joint connected the output to the intermediate shaft. A couple of angle brackets hold the unit in place.
All in all pretty simple conversion.
(4512 posts)
Re: TR6 electric steer - EPS
Date: September 11, 2019 10:05AM
First post now has pics.
oldguy
Guy Cosmo
(7 posts)
06/19/2019 09:57PM
Posted by: oldguy
Date: September 11, 2019 10:32AM
thanks Carl
dwtr6v8
Don Watson
West Virginia
(305 posts)
12/07/2007 07:45AM
Posted by: dwtr6v8
Date: September 11, 2019 07:24PM
Ken mounted his in the engine bay as well.
I would need to relocate my battery to the trunk.
I may explore this option.
Thanks for the pics!
hoyt
Hoyt Duff
(2 posts)
02/04/2009 07:12PM
Posted by: hoyt
Date: December 10, 2019 02:57PM
What car is the steering unit sourced from?
oldguy
Guy Cosmo
(7 posts)
06/19/2019 09:57PM
Posted by: oldguy
Date: December 12, 2019 06:05PM
the power unit is from a Saturn Vue, it is also used in some gm vehicles.
there are several companies that sell the control unit so that an ecu isn't needed
a pot is incorporated to control the amount of assist
it's worked out pretty well, I would like more centering of the wheel, but that was an issue without the power assist.
I plan on adding more castor for better feed back
Date: December 17, 2019 10:58AM
I've found that in limp mode the EPS units tend to give about 50% assist which is just about right. They do have a short delay while they are looking for an outside computer so initialization takes up to as much as 3 seconds in some cases. But no real need for any external controls.
