tr7v8mike Michael Booth Sydney, Australia (18 posts) Registered: 02/22/2015 10:26PM Main British Car: 1981 TR7 Rover 4.6 |
Removing dizzy
Hi, I have a RR P38 engine and I am going to remove the dizzy and install electronic ignition (Megasquirt). Does anyone know where I can get a plug for the hole left by removal of the dizzy? Rimmer Bros don't have anything.
Thanks Mike |
Re: Removing dizzy
No, but I have happily used the Lumenition Optronic system on a number of cars, retains the dizzy.
Currently in my Land Rover with Rover V8, and my Rambler with factory 327. Ivor |
TR8Driver Darrell Walker Vancouver, WA, USA (15 posts) Registered: 08/23/2019 07:59PM Main British Car: 1981 Triumph TR8, 1966 Triumph TR-4A 3.5 Rover V8, 2.1 wet liner 4 cyl with super charg |
Re: Removing dizzy
Does that engine have a crank-driven oil pump? If not, you will need something to drive the oil pump. I saw, but can't find anymore, a place in the UK that will remove the top of the dizzy and put on a nice caps.
Re: Removing dizzy
Check out the "dumpy dizzy":
[www.megasquirt-v8.co.uk] If you still need to drive the oil pump, check out the "dinky dizzy": [www.megasquirt-v8.co.uk] Edited 1 time(s). Last edit at 05/16/2020 12:04PM by TR8Driver. |
