Speedometer and tach options for an engine swapped car
Hello - hoping to get some thoughts on good options for my TR4a running a Nissan SR20DE engine. Looking for speedometer (maybe GPS based) and tach that will not look overly modern and are roughly the right size.
I suspect people here have figured that out, or may have some experiences to share. Thanks! |
88v8 Ivor Duarte Gloucestershire UK (984 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Re: Speedometer and tach options for an engine swapped car
Indeed, Speedhut
This one [www.speedhut.com]) is the speedo I used in my olde Land Rover. Not this face or font, but it's customisable. No drive cable required, which is nice. You might want a different top speed. It does looks the part in an old setting. Alas, three years on the digital mileage readout is bust. Never mind, the speedo still works and is very accurate so long as I'm not in a tunnel or under trees, Ivor |
Yes the speedhut GPS speedo drive works well with the stock 4A gage in mine. I used redline gages in CA to convert my factory tach to work with the he 5.0 in mine. I love having factory looking gage set in the dash. FWIW, I replaced the TR4 amp gage with an elan volt gage and it looks very close to Being a match.
ghornbostel Greg Hornbostel Nebraska (76 posts) Registered: 09/02/2013 01:41PM Main British Car: 1957 TR3 Buick 231 evenfire V6 |
Went to the auto parts store and bought the cheapest electronic tach I could find, removed the stock tach from the stock face and
mounted the electronic unit in its place. Replaced the electronic tach pointer with the stock pointer and reassembled the gage. Has been working great for about 10 years now. I retained the stock speedo as the saginaw trans was gear drive but a electric unit could probably be done the same way as the tack. Greg |
rficalora Rob Ficalora Willis, TX (2759 posts) Registered: 10/24/2007 02:46PM Main British Car: '76 MGB w/CB front, Sebring rear, early metal dash Ford 302 |
Speedhut are nice, but very pricey. I used Autometer "Hot Rod Designer Black" gauges on my car. Any tach with an option to use with a 4-cylinder motor should work. Some aftermarket ones have switches; some have other ways to switch them.
Speedometers are mechanically or VSS (electric speed sensor) driven or GPS based. Because their speedos have to work with so many tire diameters, almost all aftermarket electric ones are easily programmable (on my Autometer one, you put it in program mode, drive 1 mile (or maybe 2 miles, it's been a while since I did it), and then take it out of program mode. It then knows how many pulses from the VSS = 1 mile so it knows how far it is between each pulse and uses that to calculate speed. That programmable feature is way easier than swapping speedo drive gears in the trans to calibrate a mechanical speedo. And, even if your transmission is set up for a mechanical speedo cable, you can still use an electronic gauge by getting a mechanical to VSS converter. Most of the gauge companies offer them. They go in the transmission where the cable would go and convert the rotation to the VSS pulses. GPS ones don't require a cable or signal from the trans, but they're generally more expensive, some take a while to acquire the satellites when you turn the car on, and you can lose GPS signal if you drive in the city or heavily wooded areas much. When you lose the GPS, your speedo doesn't work which would annoy me. Although, I know several people who have them and are happy with them. |
