Rims
What rims and tires will fit a 1967 Triumph Spitfire, four lugs? I've read that Miata and some Toyota rims will work. Does anyone know?
dwtr6v8 Don Watson West Virginia (304 posts) Registered: 12/07/2007 07:45AM Main British Car: 1974 TR6 Ford 5.0 HO |
Re: Rims
A 4-bolt pattern.
3 ¾” (95.25mm) between centers Most on BV8 modify their rides, but......... If you are staying stock on your bolt pattern [www.triumphspitfire.com] For tires [www.triumphspitfire.com] |
Spitfire 350 Phil McConnell Perrysburg, OH (Toledo area) (240 posts) Registered: 01/11/2010 09:19PM Main British Car: 74 Spitfire 350Chevy |
Re: Rims
Is your Ford rear end the same pattern?
waterbucket Philip Waterman England (107 posts) Registered: 07/30/2011 01:08PM Main British Car: 1972 MGB GT |
Re: Rims
The only widely available rims to fit secondhand are from a MGF/TF, the wheel offset is 25/28mm. Do not be put off from buying from the UK as shipping is only $150 for DHL & $170 for UPS.
[www.ebay.co.uk] |
