What tire do you recommend?
I have Les Schwab 195 x15 Confidence All Season on my 302 conversion 4A solid axle and the car changes direction 10-15 degrees every time I hit the gas or shift
I am suspecting That the sidewalls are way too weak for the task at hand Tires are mounted on panasport true knock off Wheels, so that is not the problem Any suggestions? Edited 1 time(s). Last edit at 04/07/2021 10:18AM by Triumphant4A. |
Anarchy99 Jim Purdy Memphis, TN (148 posts) Registered: 12/06/2013 03:54PM Main British Car: 61 austin healey sprite LS6 |
Re: What tire do you recommend?
Not sure if it helps but I have G Force TA drag radials on my sprite sbc conversion. To say I do spirited driving in the car is an understatement. It'll get enough traction to pull the front end high. 225/50 R15s. BF Goodrich
