Re: 76 TR6 with GM 3.6 LFX
I see that you have done some strengthening of the mid/front chassis.
Have you considered further strengthening at the rear to minimise the flex and twist that occurs at the cruciform? |
Also the differential mount points may need to be beefed up a bit.
Malcom you mention "various strengthening measures", was this something you did all at once or an evolution of modifications?
Do you have any pictures available? I did reinforce the upper t shirt area at the back where it forms an "arch" by adding a strap inside. I've got to replace the lower T shirt which is when i will add a wider strap under and tie it together. I just dont believe that is enough. As for the weight i just meant i wanted to look for the best idea with the least penalty, Strength being the 1st priority but not go crazy. I'm open to all suggestions. Kenny |
I'd avoid encroaching on the cockpit, it will add complications, although if you do opt for a roll structure of any kind it becomes more reasonable.
Crossways round tube members of large diameter are often used to brace long frame members against twisting force. Perhaps that principle can be put to use. Plating suspension attachment points is a sensible reinforcement method in the TR frame, at any and all relevant locations. Jim |
My 4A factory chassis has an extra bridge forward of the main diff cross member.
My main intention was to fabricate a steel structure from the front of larger custom made cruciform plates to the rear diff support, linking the tops of all three bridges together. I also welded in a pair of flat plates so as to both bolt a roll cage directly to the chassis through the body and to provide a platform for mounts for telescopic shock conversions. Welding in plates to the insides of the centre chassis rails is the primary strengthening. I am having problems attaching pics, as my files are probably too large. |
The places where we saw failures were the attachment points for the front control arms, and at the rear the differential attachment points. I've also seen the rear control arm attachment points rust away. You might want to beef those up a bit.
Looks pretty good to me but I'm no expert. The front control arm brackets were especially flimsy where they are bolted through the frame rails.
