TR6 Steering Rack Position.
Hi Guys...
As we know the tie rods angle forward from the rack to the tie rod/steering arm ball joints. I currently have a bare rack mount cross member with the welded on brackets removed, I am thinking of moving the factory steering rack forward about 20mm, maintaining the same height. Apart from altering the steering column and tie rods lengths, can anyone advise as to if this would be detrimental to the steering geometry, or would it be a slight improvement. The proposal should not create bump steer as the rack height remains the same. . |
88v8 Ivor Duarte Gloucestershire UK (984 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Re: TR6 Steering Rack Position.
Don't recall from my own departed TR6, but if the rack height is such that the drag links are horizontal when the suspension is at rest with the car fully loaded, moving the rack fore and aft will have no effect on bump,
However, if there is a height difference, moving the rack so that the drag links need to be shorter, will exacerbate whatever bump steer already exists. Ivor |
When you move the rack forward you are making the angle between the ends of the rack and the arms on the spindles more extreme.
The less this angle is the more direct the steering response will be when you turn the steering wheel. As this angle gets more extreme the steering response gets less. Just draw a simple diagram and you will see what I mean. If the rack is moved a small amount it may not make much of a difference. Cheers Byron |
That's true. But in this case the rack is to the rear of the steering arms.... 'the tie rods angle forward from the rack to the tie rod/steering arm ball joints'.... so by moving the rack forwards the angle will become less extreme and so the steering will become a little more direct. Which of course makes it even more important to pay attention to bump steer, because the combination of a more direct rack and bump steer would not be much fun. Ivor |
Thanks guys....
Ivor, the rack on a TR5/6 is slightly forward of the steering arm ball joints. The TR4A rack is about 75mm back from the TR5/6 position, and is in a better position for the "Ackerman" principle to apply. |
Slightly forward. Oh, OK.
From your first post I got the opposite impression. In that case moving it further forward will just make the steering a little bit 'slower' but won't worsen any bump steer. On my TR6 I didn't notice any bump steer, just tramlining from the oversize tyres.:} Ivor |
Can anyone advise on how to find the ideal rack height in relation to ride height...theoretically.
Does the "Instant Centre" method work?....or not... because the rack/tierod pivot point is not inline with the inner upper and lower control arm pivot points. |
Instant centre... is a label for a geometric function of the suspension, so yes.
Set the angle of the tie rods to align them so they intersect the IC point. If you parse the factory setup you will likely find that this is how it is. Ivor |
