Re: Cowl Induction for Turbo Rotary Bugeye
Hey Mark
How 'bout a z-28 type bump, opening at low pressure area right in front of windshield. Not as obvious as some. |
Mark, as "Socorob" recently suggested in the body section,"autospeed.com" is loaded with sound aero suggestions, like buying a used Magnehelic brand, pressure differential gage,(1"+/- of water) suitable for aero body developement.This way you'll know the best place(higher pressure), to mount that air inlet. Good Luck, roverman.
personally i would use a scoop like on a subaru and ram the air through it.an intercooler is not an engine that has a vacuum inside to help the airflow.a front open type of scoop is the only way to go.my 2008 mustang is intercooled with a fmic and i see a big difference just removing the front lisence plate to aid the airflow.
