mtnrek@yahoo.com Chris Buckaloo Jacksonville, fl (67 posts) Registered: 02/06/2009 12:33PM Main British Car: 1962 Austin Healey 3000 BT7 Ford 289 Smallblock V8 |
Knock off hub replacement?
I want to go to a 4 or 5 lug, preferrably a 5 lug, replacement for the knock off spindles....
any suggestions where to look? thnx |
Re: Knock off hub replacement?
Machine the splined portion off. Drill hub to 5X4.75 lug pattern. Or if the bolt pattern bolting the wire wheel hubs is that already use a 1" spacer like picture below. S-10 rear has same pattern. Rear on 83-92 S-10 2WD is only 54" wide. Might not even have to be narrowed.
Edited 2 time(s). Last edit at 11/10/2011 12:44AM by mgb260. |
where do i get a spacer like this?
HealeyRick Rick Neville (489 posts) Registered: 12/19/2007 05:01PM Main British Car: 1963 Austin-Healey 3000 Ford 5.0L |
Here's another approach: [modifiedhealeys.org]
thanks for the heads up, i found the spacers at multiple locations, i just need to take some measurements on the car. then i can put it together. fo rthe meantime i'll use the wire wheels i have. they're just a lil rusty and too expensive to replace (for right now anyway). i'm planning to put some mustang svt wheels on it.... or something similar.
