metal144 Wayne Peterkin Canada (3 posts) Registered: 05/25/2018 06:48PM Main British Car: 1974-75 Jensen Healey 2003 Jag S Type1994 Jag XJS Lotus 2L Jag V8 4.2 v6 4L |
1975 Jensen Healey want Rover 3.5L with carburetors
I just bought 2 Jensen Healey's 1974 Stock and a 1975 with the drive train out really want to put in the Rover 3.5 v8 in that 75 . I'm in Canada took a look at a few projects here and any advice would be greatly appreciated want no EFI for now.
Thanks Wayne |
Re: 1975 Jensen Healey want Rover 3.5L with carburetors
Congratulations, Wayne and welcome to the forum. First time here ? First off, performance goals ? 5 speed stick ? Likely better to direct-bolt at BW T5 instead of costly/not-so-good oem 5 speed. Look over the JH with 215 in Healey section. 5 speed dif. has a better cruising ratio. If using oem exh. manifolds, Rover center-dump or Buick 300/340 will possibly fit/perform better. $'s to HP., the 4.0 - 4.6L deliver more bang/$. Any new questions/problems ? Cheers, roverman.
I been reading here and it's my first time on this forum Roverman Art you nailed just what my 1975 Jensen Healey, needs going to keep the original engine and tranny for the next owner. I need help with mounts for the engine and tranny been hunting for donor car got a ton of questions.
Thanks for your help Wayne |
