302 with Bugeye.
As a rule, I don't care for body mods, but this is so far out that the original body has pretty much vanished other than the nose and the screen frame, and really the result is quite novel.
In the process, the builder has solved that pesky problem of how to accommodate headers in an engine bay that's too narrow The 302 is backed up by a C4, probably not a bad idea on a car where it must be rather easy to break traction. Rear end treatment includes overriders, I do like to see bumpers or at least overriders. It would look better with them on the front as well, imho. If you fancy this compact giant-killer, here it is in BaT [bringatrailer.com] Ivor Edited 1 time(s). Last edit at 11/25/2019 03:57AM by 88v8. |
Re: 302 with Bugeye.
If you like innovative header routing:
