Healey Sports Cars
Healey Z
k uel
(19 posts)
09/30/2010 11:03PM
weight of Austin Healey 3000 engine, trans?
Posted by: Healey Z
Date: October 13, 2010 12:42PM
I did a search and I couldn't find it, although I am sure this has had to be discussed and is common knowledge in this forum.
I am looking for the weight of the 3000 engine as well as the transmission.
thank you in advance.
Ken
Healey Z
k uel
(19 posts)
09/30/2010 11:03PM
Re: weight of Austin Healey 3000 engine, trans?
Posted by: Healey Z
Date: October 14, 2010 06:12PM
Ok, I think I found it; 691 pounds for a complete pulled engine/trans.
Here is another source The Complete Official Austin Healey 100-six and 3000: 728 lbs with overdrive
Edited 1 time(s). Last edit at 03/10/2011 03:18AM by Healey Z.
(4636 posts)
Date: October 17, 2010 02:39PM
Good to know... thanks for posting that. (Rather heavy, eh?) I wish I could have helped.
Healey Z
k uel
(19 posts)
09/30/2010 11:03PM
Posted by: Healey Z
Date: October 20, 2010 12:17AM
1963 AH 3000 MKII weighs 2550 lbs 136 hp 167 ftlb torque engine/trans weight 728 lbs
1979 280Z weights 2780 lbs 149 hp 163 ftlb torque engine/trans weight 539 lbs
Performance of the AH was 10.9 0-60 and 17.9 in the 1/4 mile
Performace of the 280Z was 8.0 0-60 and 16.6 in the 1/4 mile
The Z performance / specs was from Car and Driver circa 1977
So, Z drivetrain has 13 more HP, one more gear and 189 lbs less.
Edited 1 time(s). Last edit at 03/24/2011 12:09PM by Healey Z.
Date: October 20, 2010 04:29PM
One more reason for a V8, roverman.
62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
Posted by: 62Healeyhacker
Date: February 11, 2011 11:07PM
My recollection is that the 3 liter AH engine weighed a whopping 611 pounds and the 4 speed plus overdrive weighed an additional 115 lbs.Now you know why the old timers referred to "British iron".
When I replaced my tri-carb 3 liter with a 215' Buick V8 and T5 transmission the weight reduction was so extreme that after installing coil springs from an AH 4 cylinder I had to cut off 1 and 1/2 coils to get I down to perfect height.
ramon
ramon leigh
(3 posts)
07/08/2012 02:43PM
Posted by: ramon
Date: July 08, 2012 02:47PM
The horsepower/torque ratings of the Healey were made in the days of gross, not net power ratings, while those of the 280Z were net ratings. Usually gross ratings are 25% higher than net ratings. Nor are ratings made by independent testers - the automaker
does the tests and sometimes falsifies the figures.
