Healey Sports Cars
How much tire ?
Date: April 13, 2012 04:38PM
Would you believe 12.25" x 25.7" ? Yes, I'm a little supprised also. Huffaker rear quarter panel added 2.5" of wheelwell width .Standard JH shock location will likely need to be moved further inboard as it's centered front to rear, on inside of wheelwell. These tires just "might" hold a Hemi, fairly well. Cheers, roverman.
(6569 posts)
Re: How much tire ?
Date: April 17, 2012 09:27PM
Sounds suspiciously close to a Corvette tire size. 315's maybe?
J
Re: How much tire ?
Date: April 17, 2012 11:26PM
Yup. 315/35-17. "Maybe" a 275 on front, but only an 8" net width rim. Onward, roverman.
(6569 posts)
Re: How much tire ?
Date: April 18, 2012 09:25AM
I'll have to look at the size but I think a 255/45-17 has very close to the same diameter and makes a good choice for a front tire. Much more than that and you'll need to have pretty good tread depth to avoid hydroplaning. With 265/50-14's any time I got below half tread it began to feel the effects on any standing water. YMMV.
I think I'm at 8-1/2 and 11-1/2 on the rims, but of course it changes some with tire brand. The 255's are pretty common I think.
Re: How much tire ?
Date: April 18, 2012 10:28AM
Clan, "It never rains in So Cal." lol. Sumitomo II's are wet tread usable. Team 3 wheels just brought out a 9.5" rim. I'll check front for potential. 8" to 10.5" width is quite a spread front/rear. Cheers, roverman.
Spitfire 350
Phil McConnell
Perrysburg, OH (Toledo area)
(259 posts)
01/11/2010 09:19PM
74 Spitfire 350Chevy
Re: How much tire ?
Posted by: Spitfire 350
Date: April 19, 2012 12:13PM
I am running Sumitomo HTR Z tires, 315/35/17 on the rear and 275/40/17 on the front. Rims are 9.5” and 11”. The outer diameters are identical. They grip great and wear a lot better than the UTQG 180 rating suggests. These tires are cheap compared to most others. The rears are $166.00 and the fronts are $141.00. Good bang for the buck.
Re: How much tire ?
Date: April 19, 2012 02:29PM
Phil, Looks like I'm limited on outside dia. of tire, (24.5"?) and an 8" wide rim, in the front. I don't want to cut-up the front wheelwell structure. Cheers, roverman.
Re: How much tire ? Continued
Date: April 26, 2012 09:39PM
Once I put a tire on the 8" Team 3 wheel, I can't return it. How do I closely emulate the contoured fit without a tire? I'm considering taping on cardboad disks of a desired tire diameter. How about an inflated inner tube, with a strap around it's diameter, to get a close profile shape ? Next width up is 9.5", a LOT more work. A 275/40-17 tire will require serious fender mods, like at least 2"+ more wheelwell diameter to clear the steering arc. While I'm at it, might as well increase track width-right ? Do I have enough "scope creep" yet ? I had a crazy idea to "drive" the car to Coronado Island Vintage Race meet, not to race, in Sept-2012. What was I thinking ? Onward, roverman.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: How much tire ?
Posted by: 74ls1tr6
Date: April 28, 2012 12:22PM
Found some photos for you Art. These were taken last year in Morgan hill meet we went too. This car has some ghost stripes.
You may want to look David up in Turlock!
Very close colored ghost stripe!
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: How much tire ?
Posted by: 74ls1tr6
Date: April 28, 2012 12:44PM
Here is one of the front hood!
This Healey was beautifully done!
My ride showing tire size of 245/45/17 Yokohama S drives, measured almost 10" wide tread, maybe 9 1/2" foot print on the ground! Can put most of the power to the ground with these tires. With 19 gallons of gas over the tires "yes", but without the fuel not as good LOL. It gets kind of driffty back there without the fuel weight.
Here is some different style hood candy!
Re: How much tire ?
Date: April 28, 2012 02:36PM
Calvin, thanks for the pic's, their motivational ! I might make it to Button Willow, on May 5-6, another good motivator. Cheers, roverman.
Re: How much tire ? Ferrari ?
Date: April 30, 2012 09:47PM
Phil and clan. Regarding Sumitomo's HTR-z's. There was (1) slighty negative reveiw of this tire. A guy bought a Ferrari F355 with these on it. The car actually had the stuff to" over-temp the tires", I'm as shocked as anyone/ lol. He would let them cool slightly, and they always came back. I figure for Harbor Freight pricing on this level of grip and wear, maybe I'm not "ready" to own a 355. Cheers, roverman.
Re: How much tire ?
Date: April 30, 2012 09:53PM
Calvin, Why does the back of your car look like a "Healey"? lol. I'll try to get some good shots this week end. Cheers, roverman,
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: How much tire ?
Posted by: 74ls1tr6
Date: April 30, 2012 10:32PM
"Wow" Art, after looking at the back end of the yellow Jensen Healey, then the back end of my TR6, they both have close design in shape. Lol
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Re: How much tire ?
Posted by: 74ls1tr6
Date: April 30, 2012 11:19PM
Sorry Art for the thread change, but more motivational photos here!
This photo was taken at Sema 2011.
And guess what "Hell Yeah It's got a Hemi". Look at the tire size to get the subject on tires!
Re: How much tire ? Hemiphile ?
Date: May 01, 2012 11:09AM
After this, I should just give-up. Uggh, roverman.
HealeyRick
Rick Neville
(495 posts)
12/19/2007 05:01PM
Re: How much tire ?
Posted by: HealeyRick
Date: May 01, 2012 11:29AM
Just noticed that flamed Healey hood. Very interesting and probably lets out a whole lot more hot air than a few louvers.
Re: How much tire ? Louvers ?
Date: May 01, 2012 09:12PM
Rick, I'm thinkin with jus' the right amount of "Lucas", those flames could be Very realistic. I'm going with Captain Nemo louvers on Hemi Healey. Should help it "dive" into the corners/lol. roverman.
