Almost done V8 Bugeye SBC 383ci
After 2 1/2 years of work my 1961 Bugeye drove and stopped on its own power today
Chevy stroked 350ci to 383ci TH350 Trans Ford 9" rear Wilwood MC Fiberglass nose Box frame SSBC rear brakes MGB / Spitfire front brakes Much more [www.ahexp.com] [attachment 16736 20150716_130622.jpg Edited 2 time(s). Last edit at 07/16/2015 11:00PM by ccsct203. |
Re: Almost done V8 Bugeye SBC 383ci
I like it!
Looks as if it will have no problem keeping the entertainment meter pinned. Live like you mean it Fred |
Anarchy99 Jim Purdy Memphis, TN (156 posts) Registered: 12/06/2013 03:54PM Main British Car: 61 austin healey sprite LS6 |
But soooo much freaking fun. Ease into the 400 hp thing... It gets fast in a hurry with a super light car
It's probably less with the fiberglass bonnet. I'd like to see how the engine fits specifically in the hood area... I'm always looking for ways to lower mine to put another good on the car
Don't be surprised if the car ends up weighing a little more than you think, little things that you don't think about add up. For example, on my car the coolant capacity increased from 12 pints to 5 gallons and the fuel tank went from 12 to 16 gallons. That accounts for over 60 lbs of extra weight just from additional fluids. But the good news is that even if your car weighs 2000 lbs you still have a better power/weight ratio than the new Z06 Corvette and Viper. I also wouldn't be surprised if that 383 makes more than 400 hp. No matter what it weighs, with an 80" wheelbase it will hold your attention.
Edited 1 time(s). Last edit at 07/23/2015 12:48PM by Jim Stabe. |
...with an 80" wheelbase it will hold your attention
It certainly will. Especially in the wet on what look like wide rears. You might like to take it somewhere and practice spinning it, before it happens for real :} Great to see a car nearly finished. So many stalled projects. Ivor |
I've got wide Mickey thompsons drag radials on mine and have driven a handful of times in the rain no problem. I have to drive mine like a motorcycle because it's tiny and people will run you off the road. Handles great for what it is, but suspension is the key. I started to read all the stuff on ahexp and I just quit reading because of the "what a waste of a car" comments. I think it's awesome and owning one with similar power, I can tell you, you'll reach for the keys to that car every sunny day, I know I do... The weight thing should be below 2000 lbs, especially with the fiberglass bonnet. Hell, the all steel, gt6 I just bought with ford 9 inch, th409, and iron headed 350 comes in at 2022 lbs and its a bigger car.
Sidecardoug Doug Rowe Northern Nevada (51 posts) Registered: 07/04/2012 05:09PM Main British Car: 1969 TR-6 Ford 302 |
Clay - beautiful car ! There was a guy named Larry Oda in Monterey, CA that had built one with a 327 & B&M Hydro back in the early 60's...it was a pale yellow, had minilites on the front & 14" Halibrands on the rear, shod with Bruce's Tires cheater slicks. He was a student at the local community college, and it was his only means of transport. I remember it being the "Isky Car of The Month" in Hot Rod, as he regularly drag raced it.
Doug |
80" wheelbase, good Lord! I had a Kirkham Cobra with 90" wheelbase 496" aluminum side oiler, 717hp. 2150lbs. It really liked to get sideways or backwards, but it was fun as hell to drive. Be careful, have fun.
