florianscholz chris scholz Iowa (24 posts) Registered: 12/05/2014 08:06AM Main British Car: 1959 BN4 100-6 5.7 V8 LS1 from corvette/camaro and 4L60E |
U joints for modifying steering shaft for LS1 V8
I have my LS1 V8 in my Healey 100-6 and due to its width, I have to modify the steering shaft with two u joints. These u joints are sold as 3/4" and the shaft going into the steering gear box is 7/8". I could machine a coupling adapter to make this work. Any other ideas?
Re: U joints for modifying steering shaft for LS1 V8
Hello Chris I think if you look on ebay you will be able to find the u joints you need pretty sure you can get 7/8" check it out good luck Bill G
A UA150100 Woodward steering joint weld 5/8" to a 3/4" would probably work for you?
[www.woodwardsteering.com] look in the u-joint section Calvin |
