Bn2 redesign front suspension help needed
Hello all. I have a 55 100/4 and want to totally get rid of the knock off wheel retention and update to disk brakes and rack and pinion steering. I have researched and all I find is vague mention of MGB parts usage...does anyone have more information, such as year, will spindles fit ect. Truthfully I toyed with the idea of Mustang 2 but it seems a little too wide. I could live with the original lever shock as I have one of the old Koni shock kits still in the box. I have a stroker 383 SBC, TH350, and 12 bolt with turned down Ford axles and 4.56 posi in it. I guess what I'm saying is I could go in either direction.....Tubular A arms and spindles or just updating the stock to disk. Cant race with knock offs so they have to go.
Any help or suggestion would be greatly appreciated......Thank you, Phil |
Re: Bn2 redesign front suspension help needed
No one knows?.....Any idea where I could find MGB front end measurements? Ive looked and looked and the foreign car wrecking yard here closed years ago. Thanks
HealeyRick Rick Neville (489 posts) Registered: 12/19/2007 05:01PM Main British Car: 1963 Austin-Healey 3000 Ford 5.0L |
This will give you a start: [web.archive.org]
