Re: overheating issue
I am trying to add more pictures but it seems that they need to be less than 1000 KB and all of mine are more than that Any one have a suggestion on how to take a picture that is less than 1000 KB
Spitfire 350 Phil McConnell Perrysburg, OH (Toledo area) (202 posts) Registered: 01/11/2010 09:19PM Main British Car: 74 Spitfire 350Chevy |
I resize in "Paint" Lock aspect ratio and resize to 20 % works for me.
Pusher fans do not work as well as pullers. A shroud improves a puller fan's efficiency. |
88v8 Ivor Duarte Gloucestershire UK (818 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Hello and welcome.
Ha! I was wondering how many cylinders you have in there then I realised it's two pictures stitched together. Another resize option, in Pictures, with the pics in thumbnails, right-click on the pic and choose Edit, then in the top menu bar there's a resize option. If you want to keep the original pic full-size, when you're done choose Save As and call it dididly dum Smaller. So, is this a new build? Has it always overheated, or is this a new problem? What if it sits at idle? The 327 in my Rambler boiled over in two minutes from cold when I bought it - fuel pressure wrong, timing wrong. Would have been great for a short-order kitchen. Ivor |
Moderator Curtis Jacobson Portland Oregon (4481 posts) Registered: 10/12/2007 02:16AM Main British Car: 71 MGBGT, Buick 215 |
For photo sizing... several websites also offer free online tools. It's been a while since I used one, but I just now did a web search for "online photo resizer" and found a couple candidates.
So... has your engine actually boiled over? I'm not sure that you really have a problem, because in my experience most engines are happy to run all day at 200F. You're running at least a 50/50 mix of antifreeze to water, right? Your cooling system is pressurized, right? So, your engine shouldn't actually boil over until somewhere around 225 or 230, right? I think 210 to 215 is a good target temperature: low enough to keep pressure down where things don't leak, but warm enough for best efficiency and for any condensation in the crankcase to be vaporized. For peace of mind... do you have a way to verify your gauge, temperature sensor, and thermostats? Back in the day, I verified all the system components I could... in my kitchen, in a saucepan of water, on my stove. (It's helpful to have a good thermometer and a multimeter.) |
Pressurised..... good point.
Are you sure you have the correct poundage cap on there? Correct for the engine that is, not 'correct' for the original car? Sorry if that's stating the bleedin obvious but it wouldn't be the first car to be running the wrong pressure cap. Ivor |
