Healey Sports Cars
Goto Page: 1234Next
Current Page: 1 of 4
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
1960 AH 3000 BN7 1967 Ford 289
Intro new member BN7 with 289 project
Posted by: 3000bn7
Date: March 26, 2024 10:27AM
I just joined here, this project has been underway since 2007 with a recent burst of effort. I'll post some of the history and slowly bring it up to date. This is the car as purchased in CA by the PO. I bought the car in MA as a shared project with an old friend who has the shop space and skills to build the car.
It had a 289 with automatic trans. The interior was badly done. Our plan is to restore the appearance to classic Healey spec and build the mechanicals to modern spec.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Re: Intro new member BN7 with 289 project
Posted by: 3000bn7
Date: March 27, 2024 10:18AM
We discovered that the motor mounts had cracked the frame and needed to be redone. A few close friends that were helping with high level fab stuff are big time drag racers so they suggested using a motor plates front and rear. We did this but finally decided to go back to more conventional mounts.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: March 28, 2024 09:32AM
This is the more conventional motor mount we ended up making. We kept the mid plate to add stiffness to the cowl area, just clearanced it for the bellhousing. I don't think I have photos of this, but during the discovery and repair of the frame damage from the poorly done mounts, we slid 2x3 square tubes inside each frame rail and plug welded them along their length to both strengthen the frame and also make sure the mounts had a secure foundation this time. The old mounts were just rectangular tube welded to the top of the frame.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: March 29, 2024 10:46AM
The front suspension is now a coilover design. The expert TIG welder I mentioned made the control arms from CrMo tubing using jigs that I made. I designed with 1 deg of negative [instead of +] camber and the same 2 deg of caster that the original design had. I kind of wish put in more caster after thinking about it for 10 more years!
We used the Healey spindles. We tried a Mustang II spindle but it would not with with the space available.
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: March 29, 2024 05:12PM
Nice car! Welcome to the forum!
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 01, 2024 09:08AM
I should go back a bit. After the cracked motor mounts were discovered and the frame inserts were in, a few more repairs were in order. Some simple floor and sill repairs. The sills were reinforced with 1x2 square tubing inside.Our 'frame table' is an old lift that was removed from a longtime Ford dealership. The chassis was welded to this while all of the fab and repairs were being done.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 01, 2024 12:57PM
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 02, 2024 05:32PM
Those with sharp eyes will have already noticed the rear frame mods. Our first attempt/idea was to create the dipped frame like a BJ8 has to increase suspension travel.
It was pretty obvious this would have limited benefit so the current build is to make the frame go over the rear axle.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 03, 2024 02:24PM
Scott, a late Thank You for your welcome and comment. Back to business, a bit more detail on the rear frame area showing the 4 link suspension.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 04, 2024 09:44AM
Upper angled bar mounts for axle housing,
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 09, 2024 04:57PM
Just for fun, a picture of one of the several distractions that came along to drag this project out. Corvette 327 with 3 carbs, crazy widened body for the rear axle.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 12, 2024 02:03PM
This is the read end, a narrowed Ford 8". I found what was probably the last Currie aluminum center section. It is built with a Tru-Trac LSD. This is a Torsen style differential. 3.5 gears.
Bearing end being prepped for welding.
Rear assembled
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 12, 2024 02:05PM
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 18, 2024 11:00AM
Back to the front. We bought undrilled Wilwood rotor hats and drilled the to mount the splines. Worked great. Nice vented discs on both ends.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 18, 2024 11:02AM
Looks like my memory is poor, I guess these were redrilled, not undrilled to start with.
Edited 3 time(s). Last edit at 04/18/2024 11:09AM by 3000bn7.
HealeyRick
Rick Neville
(495 posts)
12/19/2007 05:01PM
Posted by: HealeyRick
Date: April 21, 2024 01:15PM
Very cool project with a lot of nice fabrication work being done. Can't wait to see more progress. I see you are in MA. Whereabouts? I'm on the North Shore.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 22, 2024 09:44AM
Rick, thanks for your note. I am in SE Mass, Car is in Western Mass. I have a small machine shop here as part of my business that I can do some of the smaller parts along with design work. I put the front part of the frame in CAD to work on the suspension. This was an early attempt to use Mustang II spindles, doesn't work because of the large kingpin angle and where the upper control arm would need to be.
[attachment 23301 MIIspindle.jpg]
Edited 3 time(s). Last edit at 04/22/2024 11:34AM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 22, 2024 09:48AM
mr.redline
Steve Fickert
(1 posts)
06/27/2011 09:18PM
‘60 AH 3000 BN7 Ford 289
Posted by: mr.redline
Date: April 22, 2024 09:55PM
I am the 2nd 1/2 of this BN7 build. A little background, my name is Steve. Art and I have been great friends since we were 10 yrs old!! Almost 54 yrs later, here we are still messing with cars like we did when 16 yrs old. I’ve been a self employed car guy since I left college in ‘82. We both had big Healeys when we were younger. Back when you could buy them for extremely short money. This project has changed a few times over the years. I’m happy to say, that it is running again after 23 yrs. I have car at my home shop in Western Ma. The plan moving forward is to get the car roadworthy and driving for this season. If all shakes out as planned, car will get torn apart for proper chassis painting and detailing this coming winter. The body may or may not get done at that point. The focus is going to be on chassis and drive train. I will post updated pics as soon as I get a chance. The car build is much further along than what has been posted.
Steve
3000bn7
Art McKinley
Westport, MA
(51 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 24, 2024 12:07PM
We did need to cut into the shock mount area to make space for the coilovers.
A taller structure was added for the upper shock mount.
Goto Page: 1234Next
