Healey Sports Cars
Goto Page: Previous123Next
Current Page: 2 of 3
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
1960 AH 3000 BN7 1964 Ford 289
Re: Intro new member BN7 with 289 project
Posted by: 3000bn7
Date: April 26, 2024 02:01PM
Better picture of upper shock mount and upper control arm mounts we made.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 29, 2024 03:16PM
I don't have good photos of the front caliper mounts. CAD renderings here, maybe Steve can take a few. These are radial mount calipers so the mounts are simple, just angled brackets to line up to the ears on the Healey spindles.
Edited 1 time(s). Last edit at 04/30/2024 02:20PM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: April 30, 2024 02:24PM
I found a bunch more photos on my phone from texts that came from Steve. Here is a better shot of the rear end than what I posted earlier.
Edited 1 time(s). Last edit at 04/30/2024 02:25PM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 02, 2024 09:46AM
This shows the rack and pinion from an MGB that we shortened both the rack section and the steering shaft. This is a new rack which I noticed has a smaller pinion gear then the originals. If it turns out to not feel good, we can always mod a used rack. This shows just the housing shortened, we cut and slid a tube over the existing tube with the holes to be able to plug weld it.
We also needed to lengthen the tie rods, this shows an added section we made that got welded to the existing tie rod.
This shows a mockup of the rack position. There is a flat plate the we tacked in place to get the final width of the rack. The goal is the have the upper and lower inner control arm mounts in line with the inner tie rod joint at the end of the rack. As the rack moves, that does change, so like everything in life it is a compromise to a small extent. This is to minimize bump steer, an effect that causes a toe change as the suspension travels.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 07, 2024 10:08AM
A not so great quality picture of the bump steer checking setup.
Also not so great, shown the final rack mounted. Mounts are hard to see from this angle.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 14, 2024 11:58AM
Best picture I have of the finished rack install. You can just see the lower U joint.
This shows the upper steering shaft. This is from a TR3 which presented a few issues for the steering wheel, more to come on that.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 16, 2024 11:50AM
We had a steering wheel hub that we wanted to mod to use an E-Type wheel. I was having a hard time getting them to mate and an original E-Type wheel probably should not be cut up. I cut the spokes and turned the OD and stopped there about 5 years ago.
These next 2 are current, just taken, our welding friend helped to convert wheel center to adapt to a better wheel for the Healey.
For now this will work well. I still want to make the trafficator work. Since we have a hollow upper shaft we can run the wires through the U-Joint and wrap them to allow them to go with the steering rotation. We need to add a deco piece to the center, maybe an old shift knob logo piece. Steve put the horn and blinkers on manual switches for now.
Edited 1 time(s). Last edit at 05/16/2024 11:53AM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 22, 2024 04:35PM
The 1967 289 engine getting a 'rebuild'. It was blue but we decided it should be black as it would have been earlier. It ran very well when we first bought the car so it should run much stronger now! The Erson chrome valve covers are OK but we have some nice aluminum Ford Racing items that should look better.
A bit of Ford geekout here. This Rotunda engine crane was bought from a local Ford dealer that was closing in about 1980. We split the cost, I think it was $275. Rotunda was the tool division of Ford that sold to dealers. Fun to use it on Ford projects. The first pictures in this thread show the car in that dealership building when it was rented by Steve in later years. He found records in the attic of cars bought by his grandparents.
Edited 1 time(s). Last edit at 05/22/2024 05:23PM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 24, 2024 02:21PM
The driveshaft tunnel had been hacked pretty badly so we ordered a new one from Norman Nock's company. It requires mods for a 2 seater. This shows the old tunnel cut out and the driveshaft and new emergency brake cables. The emergency brake uses small drum brake shoes inside the brake discs.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: May 30, 2024 04:01PM
We decided to use a dual circuit brake master cylinder. Shooting from the hip a bit on the bore size since the Wilwoods are not offered in too many bore IDs.
We took a stab at changing the motion ratio of the brake pedal to compensate for the larger bore of the master cylinder.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: June 04, 2024 09:23AM
Another effort by the mad TIG welder, Chris. We were gifted an aluminum fuel tank that had the pickup damaged in an odd way. Chris fixed the problem and then welded a block that can mate to the fuel system through the trunk wall. This car has a mechanical fuel pump so it is pretty simple from here on.
They drilled into the pickup for some reason without realizing it was angled, so they drilled through the tube and it was sucking air.
Edited 1 time(s). Last edit at 06/04/2024 09:31AM by 3000bn7.
HealeyRick
Rick Neville
(495 posts)
12/19/2007 05:01PM
Posted by: HealeyRick
Date: June 11, 2024 12:30PM
Project is coming along great. I grew up in Middleborough and a guy during the '70s put a 289 2bbl and C4 into a BJ8. He won many a street race and inspired me to do my Nasty Boy in later years.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: June 12, 2024 05:23PM
Thanks for following along. All the cars we knew in younger days were very stock. I think we had heard of a Healey with a Chevy V8 in Easthampton but never saw it!
These show the cooling system, we used a dual pass radiator with 2 fans. Fits pretty well and should work well. I hate the fan noise from a stock [Healey] fan so this should be nice. I have one of the later fiberglass fans in a BJ7 and it is much quieter.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: June 17, 2024 09:43AM
This is a bit off-track but I wanted to give a shout-out to Chris, our buddy who helps so much with welding. The guy is really talented and committed. He builds these incredible cars, works hard and is raising a family! The link below goes to a video showing his recent build.
[www.google.com]
Edited 2 time(s). Last edit at 06/17/2024 09:46AM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: June 25, 2024 11:29AM
The exhaust that came on the car was pretty weak but we are putting it back on to be able to run it and do other debugging. Headers look to be homemade which is pretty 'period' cool. I like the small dia primaries because the ports are tiny on the stock iron 289 heads. They got beat up a bit over time and distorted during some repair attempts and welding practice on our side. The flanges should be able to be straightened and used short term.
I only have a picture of the RH side header and no pictures of the piping. I need to get some, it is pretty funny. There is an almost 90 deg bend below the collector on one side. It ran well and sounded great though!
If you look at one of the steering posts you can see the top of the LH header installed.
Edited 1 time(s). Last edit at 06/25/2024 11:30AM by 3000bn7.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: November 27, 2024 01:12PM
This has been quiet over the summer. Steve bought a building that needed attention so that was the priority. We have gone down a few not-very-intersting rabbit holes. The car never had wipers after it was built in CA and we need them here for inspection these days so we are digging into that. A friend in Westport has taken many Healeys apart so he donated a few wiper motors and a friend of Steve's also donated one. Out of the 3, one is working, so I am going to clean it up.
Steve reminded me that the rear reflectors were weird from the original build. I was already in the process of fixing a similar issue on a BJ7 that was lightly modded many years ago by a friend and bought by us a few years ago. He put some lights in that spot but they don't look good. I have some 12V LEDs that seem to fit nicely into the proper reflectors with a bit of minor surgery. I ordered 3 more reflectors from Sports & Classics, fingers crossed that the are correct looking.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: December 04, 2024 09:42AM
We decided to buy proper headers for this, the old ones would not seal. As cool as they were being from the original old school build, they were pretty hopeless. Knowing that headers would require mods, they actually fit in pretty well. The outlets are right over the frame, that will be solved with some clever welding and fab by good old Chris....
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: December 06, 2024 09:19AM
Most of the little stuff is done on the left side. Spring rates will be the big area of interest once the car can be driven. I chose the front rates a long time ago based on a stock Healey, which is will probably be too stiff. Time will tell.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: December 11, 2024 05:21PM
Another update on the left front with brakes installed.
3000bn7
Art McKinley
Westport, MA
(43 posts)
03/26/2024 10:05AM
Posted by: 3000bn7
Date: December 17, 2024 09:54AM
Installed travel limit straps on rear axle.
