mtnrek@yahoo.com Chris Buckaloo Jacksonville, fl (67 posts) Registered: 02/06/2009 12:33PM Main British Car: 1962 Austin Healey 3000 BT7 Ford 289 Smallblock V8 |
Front suspension?!
I've across something with my 62 healey and can't figure it out to save my life. Appearantly it has an aftermarket suspension on it. I know the Austins have a strange suspension set up to boot, but mine has another addition to it: It has regular newer style piston shocks in addition to the lever shocks.
My question is: A) has anyone seen this? and B) where can i get replacements for it? i'll add foto's as soon as get home tonight. |
HealeyRick Rick Neville (495 posts) Registered: 12/19/2007 05:01PM Main British Car: 1963 Austin-Healey 3000 Ford 5.0L |
Re: Front suspension?!
Koni used to make a tube front shock conversion. If the shocks are reddish-orange it could be the Koni set-up. Otherwise, its probably a home brew and your best bet is to take the shock to your local NAPA and see if they can source a replacement.
Rick |
thanks for the response. I do appreciate it.
Here's a link to a home made version: [modifiedhealeys.org] There are some part #s written on the shocks if you look closely.
Nasty Healeying, Rick |
I believe a number of companies have marketed telescoping front shock conversion kits for MGB (many, many years), so it'd surprise me if they haven't been available for Healeys too.
These two photos show the Spax version: ![]() ![]() (There are probably more photos of similar kits in the gallery section.) |
