NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
ROCKER SHAFT BOLTS!!! AAAAAAHHHHHH!!!
Posted by: NixVegaGT
Date: October 06, 2009 01:09PM
Seriously! I spend 3 hrs. taking my rocker shafts on and off to fix the next stripped bolt hole. My favorite part is I would get them all in and be torquing them down for the last time and the LAST one, with out fail, would strip out. AAAAAAHHH!!!!!
OK If you are about to swap out anything on the rockershafts and you have to take them off. Save yourself a crapload of time and just go ahead and drill out and heli-coil them all right away. GEEZ!!!
I swear! It's like screwing a bolt into icecream or candle wax!!
Edited 1 time(s). Last edit at 10/06/2009 01:11PM by NixVegaGT.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Re: ROCKER SHAFT BOLTS!!! AAAAAAHHHHHH!!!
Posted by: hoffbug
Date: October 06, 2009 01:15PM
I wonder if a stud setup wouldnt be better.. I sure ARP has something that would work.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: October 06, 2009 01:56PM
There is little doubt in my mind that it would. I think it's the shear forces combined with the stress and out they come. I used some altra-slick assembly lube. That may have helped the last couple times in... 4 of the 8 holes are helicoils now. I know the helicoils make a stronger threaded hole so it's the other holes that are a problem now.
(4637 posts)
Date: October 06, 2009 04:29PM
Studs would definitely be better. The bolts haven't given me trouble personally, but I understand that one of these bolts tore loose on Jerry Richards' MGB GT V8 racecar at V.I.R. in June, and it ended his weekend early and in extreme frustration. (I think it was the rearmost bolt hole, by cylinder 7, and that the rocker shaft was damaged when it happened.)
(6590 posts)
Date: October 06, 2009 06:12PM
Yep, that's about the most frustrating thing about these engines, and it's not just the rocker bolts either.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: October 06, 2009 06:28PM
The T&D shaft rocker setup Im using on the Chevelle has a stud setup.. My springs are 530 Lbs open. so yeah I can definitely see the need for studs... ARP has a full line of fasteners.. Im sure it wouldnt take long to come up with the necessary part numbers to create a stud set for just about anything.
Date: October 07, 2009 07:41PM
Nic, Helicoils are only, slightly stronger than virgin threads. I suggest peeping "Timeserts",webbsite.In my mind their the best. Are you using the Volvo shafts and rockers? Studs, always best, when you add-up the "poundage" your compressing with minimal thread engagement, using bolts. I'm thinkin a"lip" on pushrod side of stand/bottom, might help. Good Luck, roverman.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: October 07, 2009 08:53PM
Geez. Now I'm nervous. Maybe I'll look into studs. Hmmm.
nalle
Bjorn Nilsson
(21 posts)
09/29/2009 12:03AM
Posted by: nalle
Date: October 08, 2009 11:49AM
How is lubrication to the rockers solved with using studs instead of shafts? Is it like the traditional way through the push rod?
(6590 posts)
Date: October 08, 2009 04:15PM
The oil goes around the bolts or studs.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: October 08, 2009 06:25PM
I'm blocking off the oiling through the rocker shaft and oiling through the push rods instead. I had to shim up the rocker shafts and I used the shims to block the oil passage. This engine over oils the rocker shafts anyway so that will leave more for the mains!
