dbv8
Derek Beck
Barrow-in-Furness, England
(2 posts)
10/07/2009 09:35AM
TVR Chimaera 1998 450 Rover v8 4500
New member looking for advice.
Posted by: dbv8
Date: October 07, 2009 09:47AM
Hi all
i cant believe ive just discovered this site and forum.
Hopefully you guys can offer me some good advice.
I have a TVR Chimaera 450 which i drag race as well as use for pleasure and i drive to the dragstrips.
Over the last 18 months i have experimented with nitrous oxide and have cut my 1/4 mile times to 11.6 with a best terminal of 125.
I am stripping the 105k engine for a full rebuild and i intend to fit forged pistons along with ARP bolts etc. The heads are big valve 43/37mm and will be home ported and fitted with new shortened guides.
I still wish the car to be fairly road friendly but am willing to sacrifice a little in order to get benefits when injecting around 300bhp of nitrous.
I am looking for any advice and suggestions, particularly on cam choice.
Hope you can help,
Derek
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Re: New member looking for advice.
Posted by: NixVegaGT
Date: October 07, 2009 12:08PM
I wish I could give you cam advice. I haven't run my engine yet though. I was advised by Dan Jones and Woody at the Wedge Shop that these engines like a tighter LCA. My cam is at about 108º. Well here's my cam specs, anyway. My engine is a stroker so it displaces more at ≈ 5 liters. But just in case it's useful. I expect Dan and a couple other guys will chime in soon. Keep in mind that you need more compression as the overlap goes up. I make 12.5:1 CR but my DCR is 9.54:1.
LCA: 108º
Overlap: 74º
Timing: 35/71/75/39
Clearance Hot: 0.023
Lift: .544/.544
Adv Duration: 286/294
Specs @ 0.050:
Overlap: 38
Timing: 17/53/21/57
Duration: 250/253
Now there are a couple factors that make my engine different. I'm using Chevy Z28 rods that are 5.7" and the Buick 3.4" crank so my rod ratio is at 1.68:1. Your rod ratio is more like 1.82:1 so that changes things a bit...
TRip
Trip Anthony
(162 posts)
08/18/2009 01:16AM
1980 TR7 performance 4 cyl
Posted by: TRip
Date: October 08, 2009 03:41PM
Hello Derek,
If you'll be running nitros, definitely make sure you install those forged pistons. The Hypereutectic pistons ie: cast will not stand up to the increased stresses. Forged steel rods are also suggested as a reliable, strong option.
Also, steel head gaskets will help contain the increased compression pressure.
Check heads for straightness.
Since you'll be completely rebuilding the motor, I suggest looking into top hat liners and have the block checked for porosity and cracking behind the liners... as this is a major issue with these motors.
Forged crank over a cast unit.
Nicholas and others here really know what they're talking about so look to them for sound advice, too.
Trip
