dbv8 Derek Beck Barrow-in-Furness, England (2 posts) Registered: 10/07/2009 09:35AM Main British Car: TVR Chimaera 1998 450 Rover v8 4500 |
New member looking for advice.
Hi all
i cant believe ive just discovered this site and forum. Hopefully you guys can offer me some good advice. I have a TVR Chimaera 450 which i drag race as well as use for pleasure and i drive to the dragstrips. Over the last 18 months i have experimented with nitrous oxide and have cut my 1/4 mile times to 11.6 with a best terminal of 125. I am stripping the 105k engine for a full rebuild and i intend to fit forged pistons along with ARP bolts etc. The heads are big valve 43/37mm and will be home ported and fitted with new shortened guides. I still wish the car to be fairly road friendly but am willing to sacrifice a little in order to get benefits when injecting around 300bhp of nitrous. I am looking for any advice and suggestions, particularly on cam choice. Hope you can help, Derek |
Re: New member looking for advice.
I wish I could give you cam advice. I haven't run my engine yet though. I was advised by Dan Jones and Woody at the Wedge Shop that these engines like a tighter LCA. My cam is at about 108º. Well here's my cam specs, anyway. My engine is a stroker so it displaces more at ≈ 5 liters. But just in case it's useful. I expect Dan and a couple other guys will chime in soon. Keep in mind that you need more compression as the overlap goes up. I make 12.5:1 CR but my DCR is 9.54:1.
LCA: 108º Overlap: 74º Timing: 35/71/75/39 Clearance Hot: 0.023 Lift: .544/.544 Adv Duration: 286/294 Specs @ 0.050: Overlap: 38 Timing: 17/53/21/57 Duration: 250/253 Now there are a couple factors that make my engine different. I'm using Chevy Z28 rods that are 5.7" and the Buick 3.4" crank so my rod ratio is at 1.68:1. Your rod ratio is more like 1.82:1 so that changes things a bit... |
Hello Derek,
If you'll be running nitros, definitely make sure you install those forged pistons. The Hypereutectic pistons ie: cast will not stand up to the increased stresses. Forged steel rods are also suggested as a reliable, strong option. Also, steel head gaskets will help contain the increased compression pressure. Check heads for straightness. Since you'll be completely rebuilding the motor, I suggest looking into top hat liners and have the block checked for porosity and cracking behind the liners... as this is a major issue with these motors. Forged crank over a cast unit. Nicholas and others here really know what they're talking about so look to them for sound advice, too. Trip |
