HughH
hugh nutting
NW Montana
(8 posts)
01/08/2008 05:19PM
1951 MG TD MG 1250 cc
Transmission adaptor??
Posted by: HughH
Date: January 08, 2008 06:13PM
I am in the process of building a TD V-8. It will have an Olds 215. In my collection of bits is an original GM 3 speed bellhousing. I think I saw somewhere that it could be adapted to a Ford or GM T-5 or T-50 series trans. Has anyone done one, if so how thick an aluminum plate needed to give the correct spacing. And, do the Fords work mated to the original 215 crank pilot bearing/bushing? I did see this set-up in someones for sale ad that promped my question. (have seen 5 speeds linked to flathead and 4 banger Fords this way, too) thanks Hugh
mgbgtv8
Robert Milner
Manteca, Calif.
(10 posts)
12/06/2007 11:17PM
1967 BGT 293" Buick/ Rover
Re: Transmission adaptor??
Posted by: mgbgtv8
Date: January 10, 2008 12:13PM
Hugh, that pic is a bell housing for a 215 to a Ford T5, which obviously needs a spacer. If you use a GM T5 you won't need a spacer. D&D sells the bell housings you will need.
Robert
