Engine number
I’ve got an Olds engine and would like some information o, yes I did a search and found the engine number listing on this web site. Problem is when I cross checked my numbers from the tab on the right side of the block none of the numbers show up. So I was wondering if anyone would have an obscure listing that might match mine, they are as follows:
EX6742 and under that is JM547 Thanks Mark |
Re: Engine number
I also have an Olds engine and had the same experience of not finding an accurate cross-reference for my engine numbers.
We should get Mike, the Wiz, Barnes to post his engine numbers, too. How is your engine configured? Mine is a 4bbl with the 534 high compression heads, power steering, lightweight flywheel and three speed transmission. Odd that it would have a lightweight flywheel and power steering. Numbers on the engine; S201046G on pass. side head, JN335 pass. side block, CFD PM4 347044 on side of block near clutch lever. Mike's had the same 534 high compression heads as mine, and a lightweight flywheel. |
Re: Engine number
I can't figure it out either.
My olds says hi342065 on t he pass side heads. 62IM3J049 is the vin, i have a 62 cutlass. Can't tell if i have a numbers matching engine or not, but i doubt it. anyone know how these numbers work? |
