Re: Gear ratio woo`s
I think you might find Dan Masters' nifty calculator very helpful - this link will open as an Excel spreadsheet.
[www.britishv8.org] If you enter gear ratios, tire diameter, etc., the calculator correlate engine speed (shift points) to road speed for you. |
Curtis,
That is a great spread sheet. I am going to try a 3.0 ratio. It will put RPM at about 2200 at 80. Just where I think it should be. Will have to run again at MAxton and see if I'm faster that was y. Now I am at 110 at 5700 in third gear. ( 4 speed Auto.) The new gear will put me down under 4000 at the same speed. Steve |
That's a hot car, man! I love the custom headlight setup. What engine are you running now? If it's a transplant with more power I think you'll like the Ford ratio better. With more torque you won't need the extra gear and you can lower your crusing RPMs.
