Re: Lotus 907/Rover V8 head swap
Nic and clan. Initial build, I envision (2), "L" shaped pcs., profiled to interlock around peripery of deck. No increase of deck and minimal deck machining,(it's weak enough already) ! No monster crank, therefore no need to add deck height. Motor will be wide-enough , with-out. Probably the Rover, flanged, replacement liners. My stg. II Buick heads ,"want" the tractor sleeves.roverman.
Re: Lotus 907/Rover V8 head swap/Zeus anybody ?
Nic and clan, peripheral deck adapter plate will be machined flush, with minimum clean-up of Rover decks. I now have potential to buy (2)" Zeus", raw cast heads. I need to talk with anyone that has worked on same,(especially flow bench types).It's decision making time for me. Thanks, roverman.
Re: Lotus 907/Rover V8 head swap/Ecotech ?
Like I need another tangent. "Richard", of WCRCH, claims the ported version flows 425 cfm.! Anybody got bore spacing for same? What if it's 4.25" ? Way wicked Rover ? roverman.
Re: Lotus 907/ 317 cfm./Rover V8 head swap
How much can a Rover crank stand anyway? I think "somebody" posted a ("400" hp.shot), was workin ? roverman.
phongshader Justin Brown Ca (63 posts) Registered: 02/19/2010 04:03PM Main British Car: Locost Lotus 7 2.3 Duratec |
is anything happening here or was it too much work to make it worth while?
Re: Lotus 907/Rover V8 head swap? Ask FRED
Handle here is "DiDueColpi". Fred alluded to having done the impossible. No pictures or dyno report, as of yet, but we are "hopeful". Fred ??
The heads are on the engine and all the cam drives work. The intake looks like it means business, just stalled out on the crank/ cam issue. Home maintenance, trip to Spain and building an ITS Acura and a Soverin Volvo are kinda eating up all the spare time.
Did I mention that I just bought a 82 TR8 in a basket and the clutch is starting to slip on the Esprit? Cheers Fred |
I've been following this thread for a while now, and it's certainly a cool idea, but at the risk of being a heretic, why not just get a Northstar and eliminate all the problems?
I think people here don't want the easy way, but like to make it their own way.That is most of the fun in it. Plus scrounging for unobtanium parts and adapting and making your own parts. Also what if the factory did this or that.
Well put Jim. If we wanted "easy", we'd all build sbc's . That "antique" Lotus 907 head ,makes 257 hp,2.3L gas/carbs, all motor, in road racing. Two comparably prepped, on a Rover, should make for lead-dog status.
Has anything happened with this? Any pictures of the progress?
Justin, Fred Key has the gauntlet, on this one. You might "pm" him. Cheers, roverman.
chimes david chimes Reading, UK (12 posts) Registered: 12/13/2009 08:40AM Main British Car: JaguarXJ8 & XK8 Original GT V8 (just s 2ltr |
Why bother, other than the engineering challenge. Drop in a Jaguar AJ8, quad cam, 32 valve 4 ltr, 290bhp/290 torque out of the box. Plenty of them at the breakers!
David and clan, "We don't do this because it's easy, we do it bcause it's hard". Modifying our lbc's is not easy. Many new cars can be bought with ample features, performance, etc. Why bother, indeed ? For better or worse, "some" like the idea of an RV8 based swap. Maybe because of Costello or the factory GT's. We seem to be a close knit group, of strongly independant taste. Cheers, roverman.
WOW, Sept. 2012, how time flies... I consider making (4) modular cams, more of a challenge, than adapting the 907's, to the RV8.. Time will tell. Cheers, roverman.
Re: Lotus 907/Rover V8 head swap update
I had the good fortune to meet Pete Aardema, last night. Pete and his associate, are top notch, head swappers ! Like 4 valve Porshe heads on a BBC, or Subaru heads, on a Model A block,etc,etc. Pete and crew have been successful at Bonneville, for over 10 years. We discussed at length, the methods of making Lotus 907 heads, work on a Rover. He doesn't think I need a lobotamy, and at least for now, I'll take his word for it. I'll "try" to post pic's, when possible. Onward, roverman.
Re: Lotus 907/Rover V8 head swap, Update
Modular cams are progressing well. Big question is, "how crooked", after heat treat.Heat treater say's .002" TIR, is not possible. I may need to grind cam journal areas down to 25 mm, for accurate surfaces, suitable for needle bearing support. Plan is to use Honda B16, adjustable cam sprockets,(round tooth).
Re: Lotus 907/Rover V8 head swap, update 6/11
(4) 907 cams weigh 30.24 lbs. ! I think modular should be 40% less ? Honda B16 sprockets should work by step-turning the 1" spine to 22mm. Next test is to "cryo-split" the 1" needle bearings,(3 center cam journals). Cheers, roverman.
Appears to be well financed at least.
