Goto Page: Previous12345678
Current Page: 8 of 8
Re: Lotus 907/Rover V8 head swap
Date: September 05, 2014 11:12AM
They could at least, give Jim Stabe credit for the "Pfat" idea ? Whaats the budget, for a lap record ? Needs Batman to drive. So far out, why not mid ? Good Show, roverman.
Mgbgt3
Jason Shalders
Warrington
(1 posts)
12/27/2013 04:19PM
1966 MGB Gt 4.0 litre
Posted by: Mgbgt3
Date: December 07, 2014 05:21PM
Hi guys,
Just wanted to say, that the idea for this came about in 1995, so it was well before this forum was formed.. The first V8 was actually bought in 2007, so it's been planned for a long time, it's only now when I've got the opportunity to build it..
Work is going well on the engine.. We are about to have the liners fitted, we've done all of the mods to get the block able to be machined for the standard lotus bolt pattern.
We have designed and made new bottom end caps for the block to make it strong. We will be using the standard'ish spec Lotus cams and timing,mas we are using a steel flat plane crank..
In the new year, the new front cover for the timing belts will be made and hopefully by April/May we will be ready to fire her up!
There is a full build of the car and engine at www.facebook.com/APSMotorsports..
We're quite open about the build.. It's been my life Lind dream to build this engine and our MGB GT3....
Cheers Peeps!
(6469 posts)
Date: December 08, 2014 01:02AM
Jason, what are you doing about the head studs if I might ask? The bolt bossed in the block could be a bit stronger and certainly may be considered marginal for the sort of engine it sounds like you are building, then relocating the studs adds another question. Just curious.
Date: December 09, 2014 02:06PM
Jason, Will you be using a "girdle", in concert with the new caps ? A crank like that, in a 90 deg. V8, especially with moderate stroke, creates sizeable force/couple harmonics, directly to the main bearings/bulkheads. Target hp. is ? Not using a Coscast block ? Good Luck. roverman.
Date: June 09, 2015 11:31AM
Pete Aardema says this engine build is covered in this quarter of "Racing Engine Design", GB. Where to buy ? roverman.
bsa_m21
Martin Rothman
Vancouver, Canada
(216 posts)
01/06/2009 11:41AM
1980 TR7V8 Rover 3.9L
Posted by: bsa_m21
Date: June 10, 2015 11:28AM
Online here?
[www.highpowermedia.com]
M.
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: June 18, 2015 12:13PM
I bought the magazine with the car in,they are hoping to develop a kit to market the heads !
Billet sump,with longer studs to strengthen the bottom end up, I'd be interested in that,
There's no mention of the engine actually running,let alone a dyno session.
But should be going by the fall.
Date: June 18, 2015 07:19PM
"Kit to market the heads", ok you got the "kit", now all you need is a 180 deg. billet crank and bottom end strong enough to take all of the harmonic hammering, fab-up a well designed IR inlet system and exhaust, OR slice and dice (4), 907 cams, like Fred did, to use the V8 crank. Sounds easy.... roverman.
7sand8s
Dennis Miller
(36 posts)
09/21/2008 10:47PM
Posted by: 7sand8s
Date: June 18, 2015 08:49PM
Got the magazine at Barnes and Noble.
The two pictures shown were mock-ups.
Twin turbos, intercooled "each turbo capable of 650 hp."
"Camshafts specified for an output of 600-800 hp per cylinder bank."
"Maximun rpm,9300" "estimates engine should be capable of 1200-1300 hp using about 30 psi boost."
(6469 posts)
Date: June 19, 2015 09:59AM
I think that's too much to ask of a Rover block.
Date: June 19, 2015 11:22AM
Jim, I think you're right ! A few 1/4 mile passes-maybe, but the big-N, in Germany ? Big funding and big hp., I'd start with a Coscast block. Bang for Buck, would be TA heads, just not as cool. Onward, roverman.
