Re: 140 CFM Merlin Heads?
Thanks Rob. Did they also list "area under the curve" ? Stage I Buick V6 valves ? Peaked at .550" ? roverman.
Hi Dan,
I have those Vizard heads you pictured on the first page fitted to my 5.2 in my TVR Chimaera. I Bought them from Rob at V8 Developments. Its been a long term project as I have had to make up a bespoke inlet manifold and induction system and have had some teething problems but we are getting there slowly. Andy |
Andrew, we'd love to have your Trevormobile in our photo gallery. Can we get you to submit a How It Was Done worksheet?
slow_M Bernard Holzberg (59 posts) Registered: 07/18/2008 11:12AM Main British Car: 1975 TVR M series Ford 331 |
I hope this is the appropriate thread to ask the question:
Have any of you ever had the opportunity to test, or have a look at any of the REPCO heads, or the Oldsmobile Jetfire 6-stud heads? I wonder if the Olds head offers any improvements. The two major variants of REPCO heads, one, a two-valve, the other, a four-valve version certainly should. Supposedly, they were able to support 325HP, and 385HP, respectively, on a 3 liter motor, with a bore and stroke of 3.50" x 2.375". Best, B. |
Bernard and clan, being a collector of Jetfires, this head offers no performance advantage, over, say an Olds h-icomp. head. All 215 Olds heads have a shallow bathtub type chamber, with the valves moved closer to center of bore, than Buick/Rover, semi-hemi.HP quotes for Repco, do sound impressive, but dyno sheets tell a better story. Being Formula 1, I suspect the power band is narrow, and at very high rpm ? Those currently looking for serious, non-boosted hp.might best consider the bare TA heads, for potential flow vs $'s. NOT an indorsement. Cheers, roverman.
