smelfi
Steve Melfi
Alexandria Ohio
(90 posts)
04/26/2008 07:35AM
1977 MGB 302
Before I have my 8.8 narrowed....
Posted by: smelfi
Date: November 18, 2009 06:16PM
I'll soon be arranging to have my 8.8 rear end/axles narrowed. It's out of an 88 Tbird - 4 lug, posi, disc brakes.
I plan to have it narrowed to the same width with brake hubs on as the MG rear end with brade hubs on. I might have the shop make it a bit narrower than the stock MG. If it ends up a bit too narrow I can always add some shims.
I'll be purchasing a 4 link rear suspension from Classic Conversion.
Any gotcha's or tips I should be aware of before I take it t the shop?
Steve Melfi
Re: Before I have my 8.8 narrowed....
Date: November 18, 2009 08:46PM
Sounds like you're on top of things.
Does Bill Guzman provide u-bolts? You might want to ask about that. I found that stock MGB u-bolts wouldn't fit around the 8.8's tubes. Some shops actually bend u-bolts to suit, but IMHO it's preferable to buy u-bolts that have been heat treated after being bent. The shop-bent u-bolts won't have the same anti-corrosion finish either.
The shop that narrowed my axle got the spring perch angle wrong by a couple degrees, so I needed to correct pinion angle with aluminum wedges.
Date: November 18, 2009 09:41PM
Measure twice, cut once.
Wheel shims are not a wonderful thing. If your wheels center on the hub you lose that.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: November 19, 2009 09:57AM
Not to worry about Bill's 4-link u-bolts.....he now has them (and the shock/lower link brackets) sized for the 8.8 in his kit....you need to specify. (The 8.8 is 2.88" dia vs 2.5" for the stock "B" axle, if my memory serves me).
A couple of "heads up" issues come to mind. If you are welding on MG spring seats, now is the time to really investigate the documented issue of the std MG axle bias to the left side (typically 3/8" more tire to wheel opening flange measured on the left vs the right hand side). I welded on my spring seats 3/16" off symetrical and could have gone a little more (0.20") to totally centre the wheels/tires in the wheel wells.
You also need to look at your axle breather location (to ensure that it does not interfere with any of the susp upper link brackets that are welded to the axle) and look at the location of the brake drop hose "T" connection attachment (to ensure non interference during axle articulation).
(4513 posts)
Date: November 21, 2009 09:48AM
Might want to consider putting that housing on a diet by removing the excess metal.
(2463 posts)
Date: November 21, 2009 07:44PM
Also C clip eliminator kit. It uses 9" Ford pressed bearing type axle retention. I would narrow to WW axle width, about 1 1/2" narrower than steel wheel MGB axle and eliminate the bump stop hump in the wheelwell. Posi?
Edited 1 time(s). Last edit at 11/21/2009 07:47PM by mgb260.
smelfi
Steve Melfi
Alexandria Ohio
(90 posts)
04/26/2008 07:35AM
1977 MGB 302
Posted by: smelfi
Date: November 22, 2009 09:08AM
Jim,
As I've been working on the car I keep glancing at those bump stop humps and wondering if they can be eliminated so as to yield some more wheel/tire width but I haven't looked closely at it yet.
Date: November 22, 2009 10:20AM
Steve, those are easy to remove. In fact I'll be doing that mod on my car in a week or three. The details are laid out in the MGB-Roadmaster thread. Five short cuts with a zip wheel, a couple of welds, and you're done.
