crashbash
david bash
st. charles
(215 posts)
01/28/2008 10:53AM
1979 MGB Rdst V8 project, 1968 MGC GT, 1969 MGB Rd olds 215
after market efi
Posted by: crashbash
Date: October 29, 2008 05:36PM
Has anyone installed an after-market EFI on the 215?
MG four six eight
Bill Jacobson
Wa state
(325 posts)
10/23/2007 02:15AM
Re: after market efi
Posted by: MG four six eight
Date: October 30, 2008 11:21PM
What brand/type of system are you interested in? I have a Mega-squirt on mine.
Bill
Date: October 31, 2008 09:19AM
I also have megasquirt.
Date: October 31, 2008 10:09AM
Bill's EFI installation is discussed here:
[www.britishv8.org]
and here:
[www.britishv8.org]
Jim's EFI installation is discussed here:
[www.britishv8.org]
and here:
[www.britishv8.org]
(4514 posts)
Date: October 31, 2008 10:20AM
Leon Zak used a Holley TBI :
[www.zaks.com]
alana
alan atkinson
10567
(232 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: October 31, 2008 10:49AM
Just curious. Unless you are modding the engine, why wouldn't you just use the 14CU series FI?
It's dirt cheap and needs no tuning.
Date: October 31, 2008 11:35AM
Lots of people do use 14CUX, and it works well... but it doesn't fit easily under an MGB bonnet.
On my particular installation, the mass airflow sensor wouldn't fit neatly between my cowl-induction air cleaner and the Rover plenum... so, instead, someday I'd like to emulate this installation:
Lorenz Hassenstein's Rover-powered MGB with aftermarket EFI (32 photos)
http://www.britishv8.org/MG/LorenzHassenstein/LorenzHassenstein-AB.jpg
except with the L-bend adapter pointing toward the firewall, sortof like this:
(my car...)
http://www.britishv8.org/MG/CurtisJacobson/CurtisJacobson-DB.jpg
If you look closely at Bill Jacobson's installation, posted earlier, you'll notice he's also using the MGB's cowl vent for induction air. The appearance is much neater, and of course the air supply is cooler there. At road speed there's a small pressure boost too.
alana
alan atkinson
10567
(232 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: October 31, 2008 11:51AM
That explains it then.
I have a TR8. For that application, it seems ideal - plenty of space under there for the stock intake manifold and plenum. The setup is dirt cheap and plentiful on eBay.
After the time and effort spent Megasquirting the 6, no way would I go anywhere near it again if there was a bolt-on option.
V8Tech
Shaun O'Donnell
(19 posts)
01/12/2009 11:37AM
Posted by: V8Tech
Date: January 12, 2009 12:49PM
You can actually shorten the stock 14CUX or 4CU systems by around 20mm fairly easily .. i have done a few for MBG fitment ... I am told a 'C' bonnet also adds a little clearance although I have not tried it.
There is also a new 'cross over' manifold available here in the UK which uses throttle bodies or side draught carbs and should fit easily under the bonnet .. but you would need a management system like OMEX to make the throttle body installation simple .. and they could end up being rather pricey!
Just a thought:)
Shaun
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: January 14, 2009 08:03AM
Hello Shaun,
could you tell me more about your new cross over manifold. May be an pic and price.
Thank Dimitri
V8Tech
Shaun O'Donnell
(19 posts)
01/12/2009 11:37AM
Posted by: V8Tech
Date: January 14, 2009 07:07PM
Hi Dimitri, it's not mine I am afraid .... it's supplied by a competitor!!! JE Developments
[www.rover-v8.com]
but here is a pic.
