relative4 Billy Andrews Denver, CO (55 posts) Registered: 11/25/2008 02:28PM Main British Car: '80 MGB Rover 3.5 |
Timing cover seal
The timing cover seal on my '80 SD1 V8 needs replacing. The standard auto parts chains sell Felpro part 15200 as the replacement, but it's a full 1/8" too wide to fit the timing cover. Can anyone direct me to the right seal?
Bruce Mills Bruce Mills Vancouver Canada (71 posts) Registered: 11/28/2007 09:31PM Main British Car: 1974.5 MGB Roadster 3.5 Rover |
Re: Timing cover seal
While searching for head gaskets last week I discovered that the gaskets are the same for all the following.
Gaskets for Buick Skylark 61-63 Buick Special Deluxe 61-63 Buick Special 61-63 Rover 3500S 69-71 MG MGB V8 75-77 MG MGB MK1V 75-77 Triumph TR8 80-81 According to D&D "10.00 13001 Timing Cover Gaskets – For all engines, includes rope seal" I used the following for my Rover 3.5 Timing Cover Gasket set Fel TCS 13001 Water Pump Gasket Fel 129961 Hope it helps Bruce |
Thanks, I think I've found a couple of good alternatives to the rope seal that comes with that kit. Part ERC7987 from Moss Motors should do the job, and D&D sells part 49532 from AutoPart International; I'll check those out. VB's item 5-805 is much lower priced, so I suspect it may be a rope seal.
Richl705 Richard Lilly Fairfax, Virginia (42 posts) Registered: 12/03/2007 10:48PM Main British Car: 1958 MGA Buick 215 V8 |
Bruce,
This is really good information. I think it would be neat if there was a place where all this info came together. There have been many times when I found that a part for an MGA, which was very high priced, was available more cheaply for a triumph, and it was the same part. |
