Goto Page: Previous1234567891011...LastNext
Current Page: 6 of 12
Re: Serious Cams
Date: December 21, 2009 11:42AM
Lobotamy-Nic? Thaaatz jus "silly". You can't believe "everything", in a tell-all-alien, abduction. Can we just focus heere? roverman.
Re: Serious Cams
Date: December 21, 2009 11:48AM
Paul, TIG I hope? Both sides? Rollin on Riv....
pcmenten
Paul Menten
(242 posts)
10/08/2009 10:40AM
Re: Serious Cams
Posted by: pcmenten
Date: December 21, 2009 02:02PM
Art, I don't yet have my 110v welder set up for gas. I do know a gear-head that's a retired welder. I'll see if I can interest him in the project.
Re: Serious Cams
Date: December 21, 2009 04:53PM
Paul, If not, I'm thinkin brazing with map gas or ox/acet. This process will likely anneal the local area,(little heat as possible).Good Luck,roverman.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Re: Serious Cams
Posted by: NixVegaGT
Date: December 21, 2009 05:00PM
LOL
Re: Serious Cams
Date: December 21, 2009 07:25PM
Paul and all, I got 54 lifters so far,(16) soon-to-be mech.I hope their enough. No dog bones as yet. 3.1/3.4L chev. V6- right ? Amusing spyder-Nic?.
pcmenten
Paul Menten
(242 posts)
10/08/2009 10:40AM
Re: Serious Cams
Posted by: pcmenten
Date: December 22, 2009 12:23AM
Art, GM V6 lifters, Chevy V8 dog-bones, Ford 5.0 or two Buick 3.8 90^ spiders. The cam is going to be pure custom.
I'm still waiting for 24 Chevy lifters to be delivered.
We need to find something Mopar to use in this gypsy lash-up. Pushrods? Rockers?
(6585 posts)
Re: Serious Cams
Date: December 22, 2009 01:24AM
You wouldn't do much good quenching the ends, as it'd leave a soft zone in between that and the part that wasn't heated. Really the whole thing would need to be heat treated at once unless you could come up with something really clever. No ideas here though. The Buick V6 spiders sound like the best plan to me.
Re: Serious Cams
Date: December 22, 2009 11:11AM
Paul, Because the motor just would'nt be expensive enough with-out something Mopar in there? How bout a "Ram" wearing a "Bowtie"? Less frustrating, because these two never play-well together.roverman
pcmenten
Paul Menten
(242 posts)
10/08/2009 10:40AM
Re: Serious Cams
Posted by: pcmenten
Date: December 22, 2009 04:11PM
Art I'm tempted to use the Ford spider, instead of using Buick V6 spiders, just to get that brand into the combination.
Re: Serious Cams
Date: December 22, 2009 07:56PM
Paul, I thinkin this"melting-pot" theme is a little overcooked at this point, for being half-baked, that is. If you just halft to have Ford in there, go- with- the- flow, and use Henry's crank. An don't forget those Volvo rockers. "Swan Neck" intake would be nice touch.You go too far here and "someone" may rat you out to the (smog natzi's). Not a pleasant thing?
(2633 posts)
Re: Serious Cams
Date: December 22, 2009 08:47PM
Guys, I E-mailed Schneider Cams to see if they would do a hyd. roller grind. We will see.
Re: Serious Cams/bargin lifters
Date: December 23, 2009 11:17AM
60^ mech. roller lifters on the cheep. This requires making a sleeve of "exact" length between internal step and original push rod cup in lifter. Up-grade to internal circlip. Mech. lifter will be considerable grams lighter. No final weight yet. Rollin on a riv.....roverman.
Re: Serious Cams/bargains lifters
Date: December 24, 2009 04:32PM
It's official. oem. lifter weighs 105 grams w.o. oil. "Converted" to mechanical,91 grams, with hd. circlip. So Nic, with carbon fiber push rods,(in-stock), "light weight" cam, carbon fiber wrist pins,(in-stock), 370 gram pistons, 550gram,1k hp.,6" rods, LS 1 firing order. I hear a song...Rollin on a Riv....Happy Hoidays,ya'll roverman.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: December 24, 2009 11:50PM
Peace, brotha. Rollin'!!
v8ian
ian stewart
just north of London, United Kingdom, Planet Earth
(54 posts)
12/24/2009 04:06PM
67 Ford Cortina 3.9ltr Rover
Re: Serious Cams
Posted by: v8ian
Date: December 25, 2009 10:00AM
I love the idea of a roller cam in a RV8, my reservation would be can the heads flow the extra volume,, especially with the valves not being on the centerline of the bores making them shrouded by the bore sides, a lower lift, long duration cam would seem to make more sense,, what I do like the idea of it the Beehive springs, has anybody sorted these out to fit a RV8 yet???
speedybuick
Rob Franklin
(19 posts)
12/20/2009 05:57PM
Re: Serious Cams
Posted by: speedybuick
Date: December 25, 2009 03:04PM
I'm interested in a roller cam for my 300 project. currently in the parts research and gathering stage. plans call for a 300 shortblock, TA performance Rover heads and a procharger d1sc. looking for big power with street driveability. i'll be watching this thread with much interest
Re: Serious Cams
Date: December 25, 2009 03:55PM
Welcome Ian and Rob. Regarding why a roller in a Rover. Net flow under the curve, is what wer'e looking for.The small base circle and small lifter dia. of .842"(sbc.),used in Rovers and sbb's., limits the lift rates to .007" per deg. cam rotation,Max. Thanks to Chevrolet,making low cost, reliable, hyd. rollercam hardare plentiful, ie. lifters, dog bones,and "spyders with mod's". Todays oem roller set-ups provide better power,economy with reduced emissions, while lasting longer with reduced friction, over previous flat tappet designs. Our next hurdle is getting cams made in enough volume to secure good price for custom grinds. Regarding "pine cone" springs, I know of none that woun't require cutting the spring seats. At least "one" takes std Rover retainer dia. Rob, How much hp/boost? You would do well to follow what Jim Blackwood is doing. roverman.
Edited 1 time(s). Last edit at 12/25/2009 04:12PM by roverman.
v8ian
ian stewart
(54 posts)
12/24/2009 04:06PM
Re: Serious Cams
Posted by: v8ian
Date: December 26, 2009 07:27AM
Cutting spring seats is not a problem, im a engineer, but finding the right info over here in the UK for info of "On the Edge" bits and pieces is a big problem, I do like to experiment with oddball combos
Re: Serious Cams
Date: December 26, 2009 12:22PM
Ian, If this forum has "anything" ,it's lots of combo's. You may want to "peep" ,Comp Cams webb site for springs, Update, Behive pn. 26918 might be useable..65" id/top and 1.31"od/base, .625 max. lift( enough for most Rovers),lol. If your building a "Nostalgia" motor, you might consider,"394" Olds(circa 1960),pinecone springs., possibly the first, production use of the basic design. When your 3.9L buzzed 8,200 rpm., I'm thinkin, it was, "on the edge"? Good Luck, roverman.
Edited 1 time(s). Last edit at 12/26/2009 01:07PM by roverman.
