Re: Question about the Olds F85 Rocker Arms
OK you hooked me. I've searched all over as well. I've seen two references by vintage Olds builders that Thomas was a manufacturer of custom adjustable rockers for Olds engines:
Quote: I've found similar references a couple times. Not a single shred of information more extensive than that. Frustrating. I guess if they work, GREAT! Would have been cool to know if they were floating around though. |
mabie1978 Michelle Pierce Elyria, OH (111 posts) Registered: 08/25/2008 07:47PM Main British Car: 1978 MGB 3.5 Rover V8 |
Nic, sometimes they tell me a curious mind is a dangerous thing. Before long someone will lock me away :).
Yep, now that I'm digging, it looks like Thomas built adjustable rockers for the 303, 324, 371 Olds V8's. It looks like the ones you have are bushed to fit the Olds 215 shaft. Learn something every day...
[74.125.93.132] Greg |
Michelle,
Thanks for posting the pics, would be helpful if a clear picture of the push rod cup could be shown and possibly a pic of the adustor removed from the arm as I'm still not clear as to how the oiling actually works in respect of supply to the cup and the shafts themselves. Kevin. |
I would guess that it used thru-the-shaft oiling. That would be appropriate even with the tubular pushrods if the passages were available as a simple orifice could be used to limit the oil to the shafts.
In one of the pics of the F85 rockers you can see an oil hole on the valve side, presumably to positively oil the rocker tip and possibly to add some cooling for the valve springs which could be important for circuit racing use.
Kevin. |
Well according to Mark up at D&D there is not a way to use them on the Rover application. So they will end up for sale sometime in the near future. :( But thanks for all the questions and advisement.
Bitchin'! So these were around to eliminate hydraulic lifters. Interesting. I went on "street view" and looks like there is nothing there but a few VX3 tags. I wonder what happened with them.
Story is, Mr Thomas, first name, Doubting, never tried mass marketing and therefore doubted the true potential for the market, much like England for aftermarket, Rover engine parts, heads, intake manifolds were produced, didn't sell to their expectations, possibly based on less than ideal marketing, so just gave-up! Sad near-misses, roverman.
Nick,
Where the ad says collapse the hydraulic lifters, do you think this means that they are converted to solid lifters? Also made of Magnesium so any original ones might have age related issues? Kevin. |
Found this Wikepedia link that shows Bill Thomas of Thomas automotive Products as a Charter member back in the early days of SEMA
[en.wikipedia.org] Kevin. |
"Bill Thomas Race Cars", in Anaheim int the 60's. Famous race cars, "Cheetah", faster than a speeding Cobra and more $Pricey now. Michelle- you din't mention they were, magnesium.In the pic' they looked like maybe cast steel ? Even more cool than alum. roverman.
Art, I am guessing that I have both. I only brought in two loose ones from the box but one is a bit more silver while the other looks like cast steel. Magnet sticks to the steel one but not the other, at first I thought maybe someone tried to paint it a silver color but evidently the metals are different. I will get the rest of them in the box tomorrow and see what it looks like.
Michelle, another clue is mag. is approx 1/4th weight of steel. roverman.
Oops I was wrong, I think they are all magnesium. The magnet I was using was so strong it was picking up on the metal parts in the rockers. So I guess someone did try painting them.
Wow, Michelle. You are super lucky to have those rockers. What is the reason why they won't work on the Buick/Rover shafts? I don't get it.
Michelle and all , I think you were told no was because Olds "stand" is wider than Buick/Rover? Shafts should be same dia. at .812". Maybe put a spacer to make-up the differance? Double check the off-sets in a mock-up. Good Luck, roverman.
Hmmm, Don't know if anyone is still following this thread or not, but interesting. I have a set of these Thomas adjustable rockers off a buick engine. Don't know much about the buick rocker shafts bc I have an Olds F85 with the olds engine. I'll throw up some pictures later. They look very similar to the ones posted by the original poster, but instead of F85 they say B.S. my guess would be that stands for buick special?
