hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Willpower Vs Wildcat single plane intakes.
Posted by: hoffbug
Date: March 01, 2008 10:33PM
Has anyone been able to determine if the Willpower intake from Australia and the Wildcat intake from england are the same thing?
If you know differences?? please elaborate.
Re: Willpower Vs Wildcat single plane intakes.
Date: June 16, 2009 08:32PM
Tony, sorree for late response, I just noticed this. I have a Stage II Wildcat 4bbl coming ,"someday",from Ian. Port size is reportedly equal to 340 Buick,"large', only ports are raised .5"? Ian assured me, there's enough meat for me to wittle-off to match the 340 ports. As per what I can flow with the iron head? I want 220 cfm.@ 28", I may be left, "wanting". Cheers, roverman.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: June 16, 2009 10:22PM
since posting this I have bought a willpower intake.
according to Bill Laney from Australia they ( willpower) cast the intakes for Ian. the stage 1 wildcat and the willpower are the same manifold.. The stage II Wildcat is a different deal like you said.. Im not sure who casts that one.
(4514 posts)
Date: June 16, 2009 11:07PM
Great looking intake. I want one, too!
Can you measure the height for us?
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: June 17, 2009 10:28AM
as placed on the floor.
the height as measured from the floor to the top of carb pad is roughly 3 5/8"
Date: June 23, 2009 06:23PM
Oops, I just got word, I'm not getting a Stg. II but a Stg I that is supposedly ,"easy", to port to "340" size. Port size on the "pictured" manifold? Anyone had Chris Skaling port a set of Buick/Rover heads? Anyone used Loctite brand, anerobic adhesive, "sleeve retainer", for new liners? Thanks, roverman.
Greg55_99
Greg Williams
(102 posts)
11/01/2007 07:12PM
Posted by: Greg55_99
Date: June 24, 2009 10:31AM
Are you sure about that?
Top: Willpower
Bottom: 340
Greg
Edited 1 time(s). Last edit at 06/24/2009 10:31AM by Greg55_99.
Date: June 24, 2009 04:33PM
Perhaps I should ask Ian for his definition of "easy"? I may need to build from alum. sheet. As of this date, no has stated their cfm. on ported, iron 300 heads. Yes I have heard of 300 rwhp. That does't equate for me. thanks, roverman.
Date: July 23, 2009 09:31PM
Hey sbb/rover people. Forget all that and think about casting your "own" design, bottomless intake ! You could prove-out the flow with your "pattern", before you pour metal. Something to think about. roverman.
Date: July 24, 2009 10:32AM
Art, I'm going to piece together an intake rather than casting. (Don't have the foundry capabilities here yet, and may never build them.) For a one-off it's probably cheaper and easier that way, and no messing around with patterns.
Date: July 24, 2009 12:12PM
Jim, I agree, for one-off, no doubt. Some of the 350 Buick folks were complaining for the lack of aftermarket intakes. Off-course in a casting it's easier to get compound curves and fillets. The concept I proposed was to show how it's not "hopeless" for the individual to build. My local foundry charges approx. $4..50/lb for heat treated #356-T6 in "loose box" casting. By not using core boxes/etc., the bottomless intake thinks it's similar to a valve cover. roverman.
Date: July 24, 2009 04:53PM
OK, well I'm not sure just how that works, but wouldn't they require a minimum?
Date: July 25, 2009 10:36PM
It was about $75 when I had a bell housing made,(Rover to Ford C4 or Toy-Borg-OD. auto and all the GM 4/5 speeds. If anyone is seriously interest, I can check. roverman.
