ztriumph
Zack Torman
(10 posts)
01/15/2009 09:51AM
4.0 liter high compression pistons?
Posted by: ztriumph
Date: July 22, 2010 05:11PM
Hello folks,
I am wondering if anyone know of a source whee I can get 11:1 CR pistons for the rove 4.0. I am interested in building this and the only pistons I can find are the forged ones. Does anyone know of a source where I can acquire pistons for this engine?
I currently have the 4.0 with 9.35:1 CR.
thanks!
Edited 1 time(s). Last edit at 07/22/2010 05:12PM by ztriumph.
bigaldart
Alan Grimes
(18 posts)
02/20/2010 12:15PM
Re: 4.0 liter high compression pistons?
Posted by: bigaldart
Date: July 23, 2010 07:28PM
Hi,
What forged 4.0 pistons have you found, source and price please, I am looking to move to 4.0 or 3.9 Rover from the 3.5 for next year and would prefer forgings, standard bore would be handy as well. Thanks in advance.
Alan
Date: July 24, 2010 04:11PM
I suggest you try the search feature here.This has been covered in-depth, ie. "D and D", likes the 255" V8 Ford piston. VW Type IV is available in forged. Good Luck, roverman.
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: July 25, 2010 05:35AM
I think to remember me you can use Ford Pinto 3.7" bore piston.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: July 25, 2010 05:47AM
There are flat top Mahle 94 mm pistons available for VW beetle engines , IIRC they were with the 24 mm pin as 4,0/4,6 litre engines and the comp height was just about right. They have coated skirts and look quite nice. One UK engine builder advised against using them because VW engine is air-cooled with cast iron cylinders and Rover is obviously water cooled alloy block. Something to do with different design specs vs. thermal expansion etc. I do know that locally they are very popular in Pinto rally engines so they should work just fine.
castlesid
Kevin Jackson
Sidcup UK
(361 posts)
11/18/2007 10:38AM
1975 MGB GT Rover V8 4.35L
Posted by: castlesid
Date: July 25, 2010 05:03PM
Zack,
These are worth a look.
[cgi.ebay.com] ...
You need to bush the rover rods 100 thou. and check the match of rod length and compression height, i know you can make them work with a 4.6 crank and 4.0 rods. Maybe find a 4.6 crank?
Kevin.
(4516 posts)
Date: July 25, 2010 09:25PM
Hmmm, only 7 available?
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: July 26, 2010 03:03AM
[www.pacificcustoms.com]
pin is 22 mm (not 24 mm), comp height around 35 mm
castlesid
Kevin Jackson
Sidcup UK
(361 posts)
11/18/2007 10:38AM
Date: July 26, 2010 08:44AM
Carl,
7 Sets of 8 I think.
Kevin.
(4516 posts)
Date: July 26, 2010 10:06PM
Of course. Thanks, Kevin
I believe that the 255 Ford piston that Art mentioned is used in a stroker build.
Re: 4.0 liter high compression pistons?Yeah baby !
Date: July 30, 2010 06:36PM
You heard it here-first ! Diamond Racing Pistons webb-site, inventory reduction sale(-50%).List $76.70ea. They show 76 pistons in stock. 3.700" bore with 1.220" comp. dist. You get to do math for rod/stroke, to make it work. Good Luck. roverman.
