hydrocyanus
Terry Ables
(13 posts)
03/05/2010 01:11PM
64 buick 300 manual trans bellhousing
Posted by: hydrocyanus
Date: December 03, 2010 08:47PM
Hi everyone, Can someone help me with a bellhousing fitment issue, will a buick 300 1964 bellhousing manual trans bolt to a rover 4.0 or 4.6 block and if known what other buick bellhousings will work with a manual and the rover blocks thanks [also what bellhousings for the buick 350 will work with manual trans thinking of doing an iron block. Thanks everyone. Ok so will a 62 215 3 speed belhousing work with any 4 ,5, or 6 speed transmissions that you know of?
Edited 1 time(s). Last edit at 12/06/2010 11:10AM by hydrocyanus.
(2465 posts)
Re: 64 buick 300 manual trans bellhousing
Date: December 03, 2010 11:32PM
64 and up BOP GM (Buick,Olds,Pontiac) including Buick 350 is not the same as 61-63 Buick,Pontiac and Olds 215 and Rover (BOPR). Your 64 Buick 300 bellhousing will fit a 350 Buick. Hope this helps.
Edited 4 time(s). Last edit at 12/04/2010 02:03AM by mgb260.
hydrocyanus
Terry Ables
(13 posts)
03/05/2010 01:11PM
Date: December 06, 2010 11:11AM
Ok so will a 62 buick 215 bellhousing work with any 4,5,6, speed transmissions that you know of? Thanks
(2465 posts)
Date: December 06, 2010 11:24AM
Yes, 4 speed bell works with Camaro/Firebird and S-10/S-15 T5 with same wide pattern, in addition to Muncie,T-10 and Saginaw 4 speeds. D&D has an adapter for the 3 speed bell to Ford T5.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: December 11, 2010 11:35AM
The 215 bellhousings came in 2 different tranny bolt mounting options. Some modification may be required. The one I have has the wrong bolt pattern for the t5, but there is casting buttons where the proper mounting holes need to be drilled. I must have the 3 speed bell housing.
(4514 posts)
Date: December 12, 2010 12:48PM
There were 3 215 bellhousings; a 3 speed bolt pattern, a 4 speed pattern, & one with both patterns. Mine is the dual pattern, but did not have the threads tapped in the 4 speed holes.
