blown/injected 5.7L hemi
Because too much power, is never enough. "Jet" brand centifugal at approx 8 psi, E85 and( 2) 2bbl, GM tbi's. Can the factory injectors be up-graded with aftermarket,Accel, Venom,Bosch etc ? Re-flashed GM ,ecm with (4) injector drivers. Suggestions ? Thanks, roverman.
Re: blown/injected 5.7L hemi
Art, Here's what you need! 2 of these: [www.atlanticspeed.com]
Dear Jim N., I don' t suppose your suggestion has anything to do with your recent stock purchase,ie. "Fast" ? 1,800 cfm....Really ? The idea of using as much oem. equipment, as practical, so as not to sell a kidney, appeals to me. It's jus a lil' hemi, and a smaller budget. lol, roverman.
Edited 1 time(s). Last edit at 03/08/2011 07:40PM by roverman. |
Re: blown/injected 5.7L hemi/ BIG injectors
I've just been informed, I'll need approx 140 lbs/hr, X (4), on E85, 70% duty cycle @ 600 hp. Will any injector that huge ,even retrofit into GM tbi ?? Help ! roverman.
Hey Art,
Talk to a good injector rebuilding shop. Motor Man and R/C come to mind first. They should be able to rebuild and recalibrate your injectors for you. Or you can just leave the injectors out for the same effect! Cheers Fred |
Re: blown/injected 5.7L hemi/no E85 ?
Fred and clan, "Xtreme EFI" says GM tbi's not compatible with E85/alcohols. Accel "port" injectors are, with up to 160lbs/hr,(low impedence).Where get/make tb/tbi's to take port injectors ? I like concept of injectors"under" the slide plate/butterfly.How bout' oem. tb's mounted vertically ? Thanks, roverman.
Edited 1 time(s). Last edit at 03/17/2011 02:08PM by roverman. |
Re: blown/injected 5.7L hemi/help ?
Just a "little" more, please ? Evidently NOT. Why ? It's looking like Megasquirt III might be better controller, ie. cop.,E85 and supercharged ? Thanks, in advance, roverman.
Edited 1 time(s). Last edit at 03/24/2011 05:48PM by roverman. |
