Johan3500
Johan Van Wyk
(9 posts)
03/06/2009 06:17AM
Plenum tubes: a-gain?
Posted by: Johan3500
Date: April 01, 2011 06:36AM
Thank you to the gents who responded to my query on the shortening of tubes- I did not completely clarify my thinking, so please read and comment again. It seems as if the gap or space between the top of the tube and roof of plenum box is quite small and the shortening will be done only to allow an easier "turn" for the gases to get into the tubes, not more than 10 to 15mm, or 1/2". A bit like cutting the choke tower off a Holley to increase space between body of carb and ceiling of 14"air cleaner.
Thank you,
Johan
Re: Plenum tubes: a-gain?
Date: April 02, 2011 11:47AM
Your theory seems sound but without a means of testing it is unlikely someone could give you a definitive answer. You could try cutting them down about 1/4" at a time and see what improvement you get.
JB
Date: April 03, 2011 03:32AM
If I had the means, I'd also test variations of the flare itself: increasing the radius and continuing the arc further around.
(1367 posts)
Date: April 03, 2011 05:07AM
I'm in with Curtis.
Testing has shown vast differences in flow over the lip of the stack horn.
A fully radiused edge seems to have a huge advantage.
I have seen a marked improvement in stability on various carbed motors. And while not verified, an improvement in torque #s on fuel injected motors.
From a purely physics standpoint. An engine doesn't really suck in air. It's pushed in.
If you look at an intake system from that perspective everything changes.
Think of the engine as a valve allowing the air to enter rather than a device sucking it in.
Once you truly grasp that idea the power, so to speak, is yours.
Date: April 03, 2011 12:58PM
Johan, Back on March 26th on your other thread, same subject, I suggested looking at what the "specialist" have accomplished. These mod's have all been done and verified. There is no mystery here. Good Luck, roverman.
