rkas3882 randy kassed (84 posts) Registered: 05/30/2010 09:14AM Main British Car: 1973 mgb gt rover 3.5 |
o2 sensors to use with rover efi
Hi guys, I have a Buick 215 that I'm going to put the rover hotwire eli on from a rover 3.9 engine. I couldn't get the o2 sensors & I'm wondering if I can just use any 3 wire o2 sensors? Any help Is appreciated, Thanks
Randy |
Re: o2 sensors to use with rover efi
There was a thread awhile back on the MGEperience V6/V8 board. You have to use the Rover ones,they work backwards from the others and have different threads also.
cgill Chris Gill Salmon Arm, British Columbia (129 posts) Registered: 08/13/2009 12:06AM Main British Car: 1979 MGB roadster Buick 300 stroker with EFI |
Hi Randy,
This thread may help.... [www.mgexperience.net] and this one.. [www.jpurnell.com] The other option is to see if there are any local rover clubs in your area. I contacted one close to me and found a set of oxygen sensors. Cheers, Chris |
