Cleaning aluminum blocks
Sorry for the rather basic question. I did some searching and didn't come up with anything right away. I got my Olds 215 block stripped down and now I need to clean it. I was going to go with Castrol Super Clean, a caustic, diluted a bit. I think it contains sodium hydroxide as its 'active' ingredient. I may add some detergent, too. Since I have my brother's pressure washer sitting around, I'll probably hit the block with that first.
What's the standard practice for cleaning aluminum blocks and heads? |
Re: Cleaning aluminum blocks
Paul, Your going to replace the cam bearings -Right? If so, I suggest removing ALL press and thread-in plugs. Many shops can "tank" the block. Ask specifically if for alum. Look at a "recent" alum. from them. Many of these processes will destroy cam bearings. Definately No lye solution! Nitric Acid, diluted, is a good brightener. Good Luck, roverman.
I did mine old skol.. its alu, so detergent it was and good pressure washer. Once finished coat the liners well with oil and recoat as needed, button it up.
Pay attention to water galley, surprised at the grime that was accumulated |
Art, I'm going to avoid removing the cam bearings unless I find one that's got too much clearance.
Rino, I've found that Ford y-blocks and Studebaker V8's have horrible debris problems in the water jackets. I'll take your advice to heart and be sure to blast out the jackets as best I can. |
