Muncie M22 ?
Date: September 13, 2011 08:02PM
Anybody using one ? First time in Ol' #88. Thanks, roverman.
Re: Muncie M22 ?
Date: September 13, 2011 11:28PM
As I recall, Jerry Richards races with one and swears by it. Personally, I'm skeptical of any gearbox operated via multiple external linkages but I understand there are some old timers out there who specialize in setting up Muncie boxes for super-quick gear changes.
(2465 posts)
Re: Muncie M22 ?
Date: September 13, 2011 11:37PM
Art, Here is a link for more info: [www.5speeds.com]
MGB-SBC-Jimmy
Jimmy Geske
(35 posts)
01/27/2011 08:02AM
Re: Muncie M22 ?
Posted by: MGB-SBC-Jimmy
Date: September 14, 2011 12:14PM
I use a muncie m-20 in mine, I love it though Ive used more than a few in other projects over the years. I have an old MrGasket vertical Gate on mine at the moment and it shifts super fast with the straight pattern, faster than your foot! I think most aftermarket quality shifters work well too.
Re: Muncie M22 ?/ how quick ?
Date: September 14, 2011 01:46PM
I suspect being "super close" on ratios,(2.20/1), will help reduce shift times, as will 71/4" double disk clutches. I'm considering a Hurst Competition+ shifter with straight , 7" tall lever. We shall see. Cheers, roverman.
(4516 posts)
Re: Muncie M22 ?
Date: September 14, 2011 09:00PM
Yeah, in my '68 Camaro. ;) T-5 in the MG.
MGB-SBC-Jimmy
Jimmy Geske
(35 posts)
01/27/2011 08:02AM
Re: Muncie M22 ?
Date: September 15, 2011 07:51AM
One thing I gotta mention is that the shifter on mine sticks out the side of the tunnel instead of on top like the original shifter. It makes it a bit tight in front of the seat side.............
Re: Muncie M22 ?
Date: September 15, 2011 10:45AM
Good point, Jimmy. Something I had'nt thought about. TR 8 may need a tunnel mod. Thanks, roverman.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Re: Muncie M22 ?
Posted by: WedgeWorks1
Date: September 15, 2011 03:49PM
Bill Warner's Group 44 TR8 is running a nascar 4 speed that replaced the Rover LT77 that had close ratio gears.....no issue with cost or replacement parts....Nascar stuff is every where!
joe_padavano
Joseph Padavano
Northern Virginia
(157 posts)
02/15/2010 03:49PM
Re: Muncie M22 ?
Posted by: joe_padavano
Date: September 16, 2011 09:30AM
"One thing I gotta mention is that the shifter on mine sticks out the side of the tunnel instead of on top like the original shifter. It makes it a bit tight in front of the seat side............."
Hurst makes a lot of different sticks. On my 1970 442, for example, the stick has a dogleg that puts it about centered above the tailhousing. Yes, the shifter mechanism is still on the side, but the stick is offset from there. This was done to fit the factory console.
MGB-SBC-Jimmy
Jimmy Geske
(35 posts)
01/27/2011 08:02AM
Re: Muncie M22 ?
Date: September 16, 2011 11:49AM
Thats a good point Joe! On mine, since my shifter is a V-gate instead of an H, it doesnt need side to side movement. If It was an H pattern without an offset shifter, I think there could even be some interference with the shifter and the steering wheel. I went to a 14" wheel and my shifter comes close to it.
