strange vacuum reading
Hi,
Being old skol, I rely heavely on a vacuum gauge for my diagnostic and post build analysis. However I came upon a strange reading after one of my mild 4.0 rebuilds. Everything looks good except that when I blip the engine, I expect to see the gauge run towards zero, then back up to bout 25 when I release and back to 20 or so (steady). However, with this one, when I blip , it will just go down to about 15, then back to zero (while holding rev) and then to 25 after the release and a steady 20 at idle. The build is a rather standard; rebored and sleeved to spec a 4.0, crank polished, main cap to 2thou as per specs, rings hand lapped, stock rods/piston, block decked at 3 thou and heads planed with composite head gasket, heads cleaned and polished new stock valves, springs etc etc.. Custom grind on cam ( low rpm torque), HEI, edelbrock, Holley 470 CFM, hedders coated and wrapped. Onboard diagnostics; wideband, water temp, oil pressure, vacuum, EGT (single side) , tack (all autometer sport comp) The only thing that I think could explain this is that I have too much back pressure.. Please chime in Edited 1 time(s). Last edit at 12/17/2009 10:39PM by Roverboy. |
Re: strange vacuum reading
Sounds like you have a bog. I'd check the carb for correct accel shot and tip-in.
