Resurrecting Rods, Carillos and hardness
This time around, it's Carillos.How to know if their Carillos ? These checked-in at 52rc on hardness. I's not likely you'll find any Chinese copy's above high 30's in "c" scale. These likely saw Nascar use in a Stage II Buick V6,(used). Some have rust and dings. SPS 7/16 bolts. I've been warned to check pin end bushings for wear. I'll be checking big ends for size and roundness. I shall carefully grind away rust and dings, will also glass bead. Wet mag inspect and check for straightness.If all goes well, then probably "cryo treat". Since this isn't a race motor,(only 450hp.), I feel these rods should be adequate for 80hp/cyl. Block is 4.1L production, symese bore unit, with (2) center main caps upgraded to splayed 4 bolt and a main girdle. Crank to be forged after market or billet(Nascar). Heads and intake,( 4 bbl) is latest Stage II V6. The V6 is at least 4.24" shorter than the Rover V8. This makes a transverse mid-engine swap(914), much easier. Onward, roverman.
Edited 2 time(s). Last edit at 03/06/2012 11:17AM by roverman. |
