Re: 4.5/4.9 Cadillac V8
Thanks a lot for the pics, Jim. Pretty small engine compartment, I see why they are fender dump headers. And what engine is that for? RV8? I'm new to all these engines.
Cheers |
John, Buick 215/Rover 3.5, 3.9, 4.0 and 4.6. 75-80 have a little larger engine compartment as it was designed to fit the Rover V8. The width of the 4.5/4.9 is almost exactly the same as the Rover V8 at the header flange. It is much shorter though which allows more room between motor and radiator. Simple motor mount idea:
Edited 1 time(s). Last edit at 10/02/2019 01:41PM by mgb260. |
John have you thought about a oil pan baffle, Cometic MLS head gaskets and/or electric water pump?
Edited 1 time(s). Last edit at 10/02/2019 02:02PM by mgb260. |
Jim,
Stock 4.5/4.9 oil pan has baffle built in. I'm not real sure about the RWD 4.1 oil pans. Allante 4.5 has a cast aluminum oil pan unique to itself. I can't speak on the Allante pan baffle because I have never seen one of these oil pans live before. I have been pretty happy with Fel-Pro and Victor Reinz head gaskets, but those two are the only ones I will use. Not sure on Cometic MLS gaskets. I'm not a big fan of electric water pumps. Thats one reason I went from SBCs in my Fieros to Cadillac 4.5/4.9 engines. Would the stock Cadillac water pump be a problem in a MG? Cheers, John |
John, I've heard the 4.5/4.9 water pump and gaskets are a problem. The GM Delco brand was best? Do you use gasket sealant and locktite on the bolts? I prefer the old green antifreeze over the Dexcool because it wicks and eats up the gaskets.
My73 MGB was originally for the 260 but now I have a 65 Sunbeam Alpine for the Ford V8. I have a 93 4.9 in pieces in my shop in WA. My projects have been on hold the last 6.5 years as I am in AZ working in a Power Plant. 3 more months before I retire back in WA. I have helped a few on this and other boards and plan on a performance parts business similar to yours but not on the Caddy V8. My parts business will be more to fill the gaps on what other vendors don't offer. I probably have at least a year of home improvement projects first!
John, Looks like the port spacing is pretty common. SBC and SB Mopar intakes have been modified to fit other motors. Or fabricated
sheet metal intake. Here is a pic of SB Mopar cheap offshore Air Gap intakes made to fit a Cadillac V8. I think you are onto something! Edited 2 time(s). Last edit at 10/14/2019 09:41PM by mgb260. |
John, Great work! I noticed when I pulled my motor apart the nylon cam thrust button was brittle and fell apart. Are you using something better?
Hi,
Thanks for the compliment on the exhaust. Its been a fun project. I have never had a problem with the cam thrust button before. Not sure what to tell you on that. I'll look into it. Cheers |
