Goto Page: PreviousFirst...345678910111213Next
Current Page: 10 of 13
Johns 4.9
John Leo
(17 posts)
09/30/2019 10:13PM
Re: 4.5/4.9 Cadillac V8
Posted by: Johns 4.9
Date: February 01, 2020 04:09PM
This is what 180 degree headers with dual exhaust sounds like. Sounds like two four-bangers running together in unison live and in stereo. Probably not the exhaust note for everyone, but I like it! Cheers.
[www.facebook.com]
Johns 4.9
John Leo
(17 posts)
09/30/2019 10:13PM
Date: June 25, 2020 10:27AM
New LS inspired stand alone fuel injection for the Cadillac 4.5/4.9 engine. Electronics are Fast Retrofit TPI Kit.
(2633 posts)
Date: June 25, 2020 11:47AM
John, Excellent work! Over 60,000 hits on this thread! Keep the idea's coming!
(4637 posts)
Date: June 25, 2020 07:08PM
That certainly is a handsome EFI plenum!
(2633 posts)
Date: July 21, 2021 06:50PM
Jon Olshewski, Auto shop teacher at Salt Lake City, UT East high school and his students are working on an interesting project. They discovered that 215/Rover heads bolt on with the inside headbolts and pushrod and lifters line up. Outside bolts are on the edge of the heads and would need material added for those bolts. Here are some pics of the 215 Olds heads on the 4.9 Caddy block.
RallyTime38
Jonathan Olschewski
(5 posts)
07/21/2021 01:45PM
Posted by: RallyTime38
Date: July 21, 2021 07:12PM
Jon here.
The other slightly inconvenient flaw to this is the valves are backwards. As in the camshaft lobes aren't for the correct valve. We have talked about running the engine as a Hot Vee setup or custom making a cam blank and getting a fresh one made...
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: July 22, 2021 02:18AM
Engineering and educational aspects aside, what is the benefit using 215 heads on a Caddy engine ?
(2633 posts)
Date: July 22, 2021 02:24AM
Caddy 4.9 has iron heads.
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: July 22, 2021 04:47AM
Amazing idea.
I guess the inlet manifold would be the next bit of fun.
What about the rocker oiling?
V8
(4628 posts)
Date: July 22, 2021 09:07AM
Tell them to find a set of aluminum '64 Buick 300 heads if going to all that trouble. ;)
(2633 posts)
Date: July 22, 2021 11:06AM
I mentioned the Buick 300 heads. He actually was looking at the TA heads. Pushrod oiling. The cam is the biggest ordeal.
(2633 posts)
Date: July 22, 2021 11:08AM
Carl, remember when we were trying to figure out a spider for the short V6 roller lifters for the Buick/Rover. Looks like the Caddy one would line up perfect.
(2633 posts)
Date: July 22, 2021 11:47AM
Pic of 4.9 gasket on 215 head. Bore spacing and inside headbolt holes are perfect.
RallyTime38
Jonathan Olschewski
(5 posts)
07/21/2021 01:45PM
Date: July 22, 2021 01:28PM
The catch to both of these is that the Cadillac head is only 2/3 the actual material size of the Buick 215 head. So in reality the Buick head is even lighter than this technically in what it replaces.
RallyTime38
Jonathan Olschewski
(5 posts)
07/21/2021 01:45PM
Date: July 22, 2021 02:05PM
[youtu.be]
In our application we are all about weight reduction. In race trim this has body panels on it.
Basically 2200 lbs or 1000kg and All Wheel Drive.
(4628 posts)
Date: July 23, 2021 10:47AM
Once you get it sorted, that will be a hoot in RallyCross.
(6588 posts)
Date: July 23, 2021 11:21AM
Looks like you may have some studs and exhaust bolts wanting to occupy the same space.
(1389 posts)
Date: July 23, 2021 01:49PM
That Caddy engine is a wet liner, open deck block.
I bet that there's room to move the outer head bolts inboard in the block enough to fit.
The rover cam looks close enough to fit as well, with some creative machine work.
The only real PITA would be the dist drive gear. Machine the bearing journal off the rover cam and machine the caddy drive gear and journal to press fit back onto the rover cam. Pin, through bolt or braze the whole thing together and your good to go.
Date: July 23, 2021 07:23PM
Uh, I know a guy with billet, round lobe, cam blanks ?
Art.
RallyTime38
Jonathan Olschewski
(5 posts)
07/21/2021 01:45PM
Date: July 25, 2021 10:55PM
I don't think this design will allow what you are suggesting.
