Re: 4.5/4.9 Cadillac V8
Roverman,
Are those cam blanks for a Cadillac? |
mgb260 Jim Nichols Sequim,WA (2631 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
Roverman has Rover blanks but, that is what you need for Fred's suggestion. Delta Cams may be able to modify and swap around the distributor gear if you send them the blank with a Caddy stock cam. They do a high performance regrind for the Caddy cam based on the Ford E cam specs for the Fiero guys.
Edited 1 time(s). Last edit at 07/26/2021 02:33PM by mgb260. |
Just so I understand, why 215 heads on a cast iron caddy block ? Anyone put an RV8 in a Fiero ?
So after seeing the caddy block naked, I see the issues. Relocating that row of studs is doable, sealing the head is problematic.
I think that even that spray on seal that makes your screen boat float won't save us. However, the fix for the Lover engine can save the day! Pull the cyls. and deck the block 0.500 thou. Machine a new deck from aluminum plate and sandwich it between the block and the Rover head. The inside studs line up so everyone can play nice there. The outer studs present a few more options. I would move the studs to line up with the rover head. Or you could countersink the caddy stud into the deck plate and drill the plate for the rover pattern. You could also weld the plate to the block but a failure would be disappointing. They all give the opportunity to utilize the American 6 bolt pattern if you wanted that. The other option that presents itself is drydecking the block by utilizing the deck plate to stop the wet cyls from walking around and meeting the neighbors. Machine the inside edge of the decks to accommodate a sheet metal plate to seal up the valley and you are good to go. There's more stuff but the leader of the opposition just poured me a scotchy scotch. so she's purchased something! Cheers Fred |
Maybe you could run studs or long countersunk capscrews from that plate down into the main web to tie it all together and stabilize the liners and tie the heads down. Maybe external ribs/bolt bosses heilarced to the outside of the block could be used to do the same thing though and eliminate the plate.
I Like the idea of the deck plate surrounding the liners. Kind of like a girdle on the top of the block. The intake side bolts are long and go down to the main web. The outer countersunk bolts would too. The outer head studs would be attached to the 1/2" deck plate. With a valley cover and spacers any Buick/Rover intake would work. Maybe a 300 intake would fit better?
Yea,yea, kinda like you would deck plate an RV8 for Lotus heads ? Why is a cad block so superior to an RV8 block,
it warrants all this work ? Forged crank, stronger, sustain more hp. ? |
A set of TA heads on that block should work rather well I would think.
Roverbeam Chad McNeely N.E. MO (81 posts) Registered: 06/09/2021 06:03PM Main British Car: Alpine S4 Rover 4.0 |
He mentioned a "hot vee" setup - suggesting maybe the heads fit on backwards? intake from the sides, exhaust up and out the middle? I'd love to see what that looks like!
edit: I can't see how a reversed head could work, but just because it looks so fun here's an engine with a side-fed ITB set up with top exhaust. Edited 1 time(s). Last edit at 09/12/2023 11:59AM by Roverbeam. |
I hereby rename "hot vee", Indy Jones. Parnelli not needed. Might be tight in a "B" ? Let's get serious. 7" shorter ? Forged crank ? Cader V16 ? Onward, Art.
Re: 4.5/4.9 Cadillac V8, Rod Journal width/diameter ?
I have 8620 billet, round lobe cam blanks, 4.0L up RV8. Bearing journals are +.03" os. Perhaps will machine to fit Cad 4.9L.
If anyone has these two dimensions, please ? I f anyone has these two dimensions please ? Thanks, Art. Art. Edited 1 time(s). Last edit at 10/01/2023 08:52PM by ag1234. |
Miata Lemons car build with some performance tips:
[forums.24hoursoflemons.com] Edited 1 time(s). Last edit at 10/20/2023 11:45AM by mgb260. |
