Goto Page: PreviousFirst...345678910111213Next
Current Page: 11 of 13
RallyTime38
Jonathan Olschewski
(5 posts)
07/21/2021 01:45PM
Re: 4.5/4.9 Cadillac V8
Posted by: RallyTime38
Date: July 25, 2021 10:56PM
Roverman,
Are those cam blanks for a Cadillac?
(2631 posts)
Date: July 26, 2021 01:16PM
Roverman has Rover blanks but, that is what you need for Fred's suggestion. Delta Cams may be able to modify and swap around the distributor gear if you send them the blank with a Caddy stock cam. They do a high performance regrind for the Caddy cam based on the Ford E cam specs for the Fiero guys.
Edited 1 time(s). Last edit at 07/26/2021 02:33PM by mgb260.
Date: July 26, 2021 07:13PM
Just so I understand, why 215 heads on a cast iron caddy block ? Anyone put an RV8 in a Fiero ?
(2631 posts)
Date: July 26, 2021 10:47PM
Art, 4.9 has aluminum block with iron heads.
Date: July 27, 2021 05:08PM
Ok, so why 215 heads on an aluminum caddy block ?
(2631 posts)
Date: July 27, 2021 08:41PM
Art, To get rid of the iron heads! To make the motor even lighter.
(1389 posts)
Date: July 27, 2021 09:49PM
So after seeing the caddy block naked, I see the issues. Relocating that row of studs is doable, sealing the head is problematic.
I think that even that spray on seal that makes your screen boat float won't save us.
However, the fix for the Lover engine can save the day!
Pull the cyls. and deck the block 0.500 thou. Machine a new deck from aluminum plate and sandwich it between the block and the Rover head. The inside studs line up so everyone can play nice there. The outer studs present a few more options. I would move the studs to line up with the rover head. Or you could countersink the caddy stud into the deck plate and drill the plate for the rover pattern. You could also weld the plate to the block but a failure would be disappointing. They all give the opportunity to utilize the American 6 bolt pattern if you wanted that. The other option that presents itself is drydecking the block by utilizing the deck plate to stop the wet cyls from walking around and meeting the neighbors.
Machine the inside edge of the decks to accommodate a sheet metal plate to seal up the valley and you are good to go.
There's more stuff but the leader of the opposition just poured me a scotchy scotch. so she's purchased something!
(6569 posts)
Date: July 28, 2021 09:43AM
Maybe you could run studs or long countersunk capscrews from that plate down into the main web to tie it all together and stabilize the liners and tie the heads down. Maybe external ribs/bolt bosses heilarced to the outside of the block could be used to do the same thing though and eliminate the plate.
(2631 posts)
Date: July 28, 2021 10:55AM
I Like the idea of the deck plate surrounding the liners. Kind of like a girdle on the top of the block. The intake side bolts are long and go down to the main web. The outer countersunk bolts would too. The outer head studs would be attached to the 1/2" deck plate. With a valley cover and spacers any Buick/Rover intake would work. Maybe a 300 intake would fit better?
Date: July 28, 2021 11:27AM
Yea,yea, kinda like you would deck plate an RV8 for Lotus heads ? Why is a cad block so superior to an RV8 block,
it warrants all this work ? Forged crank, stronger, sustain more hp. ?
(4615 posts)
Date: July 30, 2021 09:24AM
It's what they had. ;)
(2631 posts)
Date: September 11, 2023 04:47PM
(6569 posts)
Date: September 12, 2023 12:25AM
A set of TA heads on that block should work rather well I would think.
(4615 posts)
Date: September 12, 2023 09:36AM
Even Buick 300 heads would be better than the 215 heads.
Roverbeam
Chad McNeely
N.E. MO
(81 posts)
06/09/2021 06:03PM
Alpine S4 Rover 4.0
Posted by: Roverbeam
Date: September 12, 2023 11:37AM
He mentioned a "hot vee" setup - suggesting maybe the heads fit on backwards? intake from the sides, exhaust up and out the middle? I'd love to see what that looks like!
edit: I can't see how a reversed head could work, but just because it looks so fun here's an engine with a side-fed ITB set up with top exhaust.
Edited 1 time(s). Last edit at 09/12/2023 11:59AM by Roverbeam.
(4615 posts)
Date: September 12, 2023 02:31PM
Nope. He mentioned the valve cover sealing over part of the intake.
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: September 13, 2023 11:03AM
I hereby rename "hot vee", Indy Jones. Parnelli not needed. Might be tight in a "B" ? Let's get serious. 7" shorter ? Forged crank ? Cader V16 ? Onward, Art.
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Re: 4.5/4.9 Cadillac V8, Rod Journal width/diameter ?
Posted by: ag1234
Date: September 19, 2023 06:40PM
I have 8620 billet, round lobe cam blanks, 4.0L up RV8. Bearing journals are +.03" os. Perhaps will machine to fit Cad 4.9L.
If anyone has these two dimensions, please ?
I f anyone has these two dimensions please ? Thanks, Art.
Art.
Edited 1 time(s). Last edit at 10/01/2023 08:52PM by ag1234.
(2631 posts)
Date: October 20, 2023 11:42AM
Miata Lemons car build with some performance tips:
[forums.24hoursoflemons.com]
Edited 1 time(s). Last edit at 10/20/2023 11:45AM by mgb260.
(2631 posts)
Date: October 20, 2023 01:40PM
Pic of 88-89 4.5 dual plane intake to be used with 4.1 or 4.5 valve covers and 4 barrel conversion:
Edited 1 time(s). Last edit at 10/20/2023 01:42PM by mgb260.
