SELECTI NG A TRANSMISSION
I'm putting a 215 in a GT6+. I have the Olds 4spd bellhousing. I see that the best possible choice that I could afford is a T5. But what other makes would serve nicely that might be easier to aquire at less cost? I'd like it to be a 5spd, easily adaptable to the aforementioned bell, have the right shifter location, close ratio, and able to handle the torque of a stock 215 V8.
MECHANIST |
Re: SELECTI NG A TRANSMISSION
I suppose the most obvious choice would be the older Borg-Warner "T50" (aka "T-50") 5-speed from a Chevy Monza V8 (or other H-body). Several "British V8 guys" have used it this transmission with pretty good success, including Jeff Howell and Jim Blackwood whose cars appear in the photo gallery on this website.
Obviously, you don't see a Monza every day anymore... but if you were able to track down an Olds 4-speed bellhousing, you shouldn't have a hard time finding a suitable T50. They tend to be dirt cheap, and they're comparitively skinny and lightweight! Watch out though... you probably don't want the version that was used with a six-cylinder engine. The Monza V8 version will have much better (closer) two-thru-five gear ratios, although I've read that first gear is REALLY low. The other weird idiosyncracy of all T50 transmissions is the shift pattern. Gears two-thru-five are in a nice neat "H", but first and reverse are both to the left and (get this!) reverse is above first. There are detents to prevent you from shfting into reverse accidentally... make sure they aren't broken! |
I aquired that engine with the bellhousing about 10 yrs ago and had no idea that the bell was a rare bear. In fact I didn't know until I started this GT6 project very recently that the engine has so much going for it. I'm really excited about this project now.
The H-bodies are getting more and more hard to find. The T50's aren't too common but they're out there and like Curtis says they are pretty cheap because they aren't so desirable by the H-community because of the low torque threshold. I think it would work great with the stock 215 though. The non-WC T5's like you were saying are really pretty cheap too and fine for the stock 215 torque. The 4-speed bellhousing shares a common bolt pattern with the T10 and Saginaw too. Here's a link to some info on my build site. I hope it's helpful:
[www.cardomain.com] At the bottom I've got a pic of the T5 bolted on to my Olds 4sp bell. Good luck bro. |
Here's another option from another post:
May be overkill.. Toyota Supra Turbo R154 mated to a Buick 215 bellhousing via a Jeep AX15 adapter from Novak in Utah. [www.jeeps-offroad.com] Greg |
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (384 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3 |
T4 from about a 1982 S10 would be a cheap 4 speed and just a hair easier to fit than the T5. You can always upgrade to teh T5 later.
BTW: I fit a 3.4L with a T4 and then a T5 to a Spitfire, so it should all be about the same. The S10 tailhousing looked like it would work better than the Camaro tailhousing which is opposite form most conversions like the MGB. -BMC. |
Brian,
That is something to consider. I have determined that the tailshaft housing with the shifter mounted about midway on the housing on a T5 would put it spot on. That is, if it measures real close to 16" from the front face of the trans main case. I may also opt for a nwc instead of a wc if I find a good deal on one. One question I have not found an answer for is if the nwc and wc cases are interchangable. Bill |
