How not to loose your parts
I've been using a local engine machine shop, because they are good value, for the quality level. That being said, they have organizational problems,(parts/gaskets, everywhere). I have now learned, (have them sign a completed list of "all" the parts they received) ! I dropped-off the 4L race block, to have rough bored/no hone, so I can do a crank, rod, piston, head and valve clearance check. We measured said piston, while I was there, and discussed if it needed to stay there, to double check fit. Weeks pass and I threaten to remove said block, done or not. Big supprise, it get's done shortly thereafter. I go to pick-up and somehow let the owner convince me, "I" have the piston, since "we" measured it, and didn't really need it for rough boring.Realizing my age facter, maybe I "do" have it ? I finally give-up on finding it, and plan to order (8) new custom racing piston$$. $700-800. likely. I get a call today, from u-no-who, and they "found" my $800 piston. Long story, but maybe others can avoid my grief. Onward, roverman.
Re: How not to loose your parts
Another idea would be to shoot pictures of everything you deliver and have the shop sign off on the pictures. Probably a good idea when delivering parts to the chrome shop, too. I received some chrome pieces back from a plater for my bugeye that included a rather large headlight rim labelled "CARELLO", which I was pretty sure wasn't in the batch of stuff I sent to be plated. Few days later I got a call from a high end restorer looking for the rim that went on a 1 of 10 Maserati.
Good idea too. How much did you get for the Carello ? Do they make rods ?/lol. roverman.
I got my Lucas headlight rims back from the other guy. I should have held him up for ransom. Rest of the story was I learned later he was a well known sleaze in the high end resto business with lawsuits following him around like seagulls on a chum line. Don't think you'd want any of those Carello rods, stick with that other SoCal brand.
mtnrek@yahoo.com Chris Buckaloo Jacksonville, fl (67 posts) Registered: 02/06/2009 12:33PM Main British Car: 1962 Austin Healey 3000 BT7 Ford 289 Smallblock V8 |
had a similar issue when i took my motor in to be ran through. I picked up the motor and realised something was missing, but couldnt figure out what... When i started putting it all back together, i realized the CAM hadn't been put back... Come to find out... "oh, it was right here all along"
DEEEERRRRRR!!!!! Check lists are FTW!! |
